You are having problems with:
Solved by brian.kling. Go to Solution.
Hi yodah:
My apologies for the inconvenience.
I would like to assist you better. Please allow me to clarify my understanding of your issue. Now, are you trying to download and install Autodesk Inventor Professional 2013? If so, the product key for Autodesk Inventor Professional 2013 version is 797E1. You can find product key information here. Upon checking our record, I can only see Autodesk Inventor Professional 2012 on your account. Please remove your trial version from your machine and re-download 2013 version from Education Community for 64 bit.
In case you encounter any activation issue,contact our Registration and Activation Team for assistance.Make sure to provide the following information:
Serial Number:
Product Name:
Product Version:
Request Code:
Let me know if you need anything else.
Best Regards,
I have a serial nubmer and a product key, but when i hit Activate now via Internet (Recomended) it says
The serial number you entered is not valid. Try again
Serial is the same as on my profile but somehow it isnt working
Hi maradanovic:
For activation issue, please contact our Registration and Activation Team for assistance. Please make sure to provide the following information:
Serial Number:
Product Name:
Product Version:
Request Code:
For steps on to retrieve your request code, please click here.
Have a nice day!
Best Regards,
Hi Arlin
Registration and activation team pointed me back to the forum. Problem stil the same, my serial isn't working.
Hi Marko,
I apologize for the inconvenience. The support representative had provided all of the steps to "refresh" and activate your license (with a mention of the forums in the signature template), however there appears to be an issue with your student profile that's preventing the above from being able to take place.
With that being said, can you please create a new Education Community account with a different email address and see if that resolves it?
Thank you for the reply. Yes I can create another profile, but I thought that vas forbidden and that you check if mail is in common with the University. I will create a profile with my personal mail today, hoping it will work.
My major project is due in 2 weeks and I've fried the graphics card on my main computer which has Revit installed on it. Is it possible to get another product key/license so I can install and use revit on anther computer???
Please HELP!
Thanks.
Hi mireebum,
Welcome to our Discussions Group!
I can provide you with a new activation code. Can you send me a private message (click the envelope next to your name) with the following information:
Serial number
Company name
Thank you!
Hi Celine,
Thanks for your prompt response. Greatly appreciated.
I've PM you.
Maree
Hi currie7736,
Are you trying to Activate your Student License? If so, we can Activate it for you, Private Message me (click on my joane.bonghanoy profile name and then “Send this user a private message”) you Serial Number and Request Code.
Hello, I'm having trouble activating my copy of Autodesk Mudbox 2013 student edition. During the activation process I choose "Connect now and activate" but then I get the following message:
The serial number you entered is not valid. Try again. (1)
Can you help me? Thank you.
Hi AndreasY,
I'll help you get an activation code. Please send me your serial number and product request code by Private Message. To do so, click on my profile name (simona.golisciano) and then "Send this user a private message").
Regards
i have a product key and activation code and they worked before on inventor and now i go to install this and i have the same key and it doesn't work. why not?
Hi blueq9:
I checked our record and you have the listed products below. Please take note of different product key for each.
Autodesk Inventor Professional 2013:797E1
AutoCAD 2013:001E1
AutoCAD Civil 3D 2013:237E1
Autodesk Inventor Publisher 2013:666E1
Let me know if you're able to activate using the correct information.
Best Regards,
The serial number I was provided for the 2012 student version is only associated with the 2011 version in the autodesk data base, so therefore im unable to activate the software? What should I do?
Hi hydrokia:
As per our record, the product you have downloaded so far is only for AutoCAD 2011. You can download AutoCAD 2012 version and use the same serial number to activate. The product key though would be 001D1. For list of product keys, click here.
Let me know if you have any further questions or concerns.
Best Regards,
