Installation & Licensing
Stingray Installation problems
3 REPLIES 3
741 Views, 3 Replies
I was trying to install Stingray and as soon as I press install it goes to the install sceen and a few seconds later it goes to the finished screen.
I have included a sceenshot of the error sceen and  the installation log.
Jeff
3 REPLIES 3
Otto
Hello Im_Jeff
It looks like you need to find out more about downloading or re-downloading software, or are having issues that may be resolved by re-downloading.
For general information about downloading or re-downloading (including eligibility), Community members with similar questions found the following article(s) useful:
Previous Versions of Autodesk Software
Download Methods
Find Your Eligibility for Previous Versions of Autodesk Software
Oftentimes installation and/or download issues can be addressed by using a different download method, or by downloading directly from the Autodesk Virtual Agent. Community members with similar issues found the following article(s) useful:
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
If the link(s) helped resolve your issue, please reply with the steps taken and accept your post as a solution so that others can benefit from the information.
If not, please reply with additional details so that other community members can assist. Details may include relevant screenshots, error messages, system specifications, browser type, or any other information that you think may help.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
in reply to: Otto
Thanks for the advice in the end all I had to do was restart my computer.
I had the same problem - tried multiple version installs, no luck.  I went through the Clean Uninstall steps - primarily step 4 & 5 here - https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Delete any residual Program Files from these locations:
  • C:\Program Files\Autodesk\
  • C:\ProgramData\Autodesk\
  • C:\Program Files (x86)\Autodesk\
  • C:\Users\All Users\Autodesk\
  • C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
  • C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
The program folders should be clearly named.
Clean out your TEMP files:
    1. Click the Windows Start button.
    2. In the Run box type %TEMP% and press Enter
    3. Highlight and delete all files. Ignore any files in use.
Solved my problem and got Stingray installed.
Thanks for the help!
-HJ
Administrator Productivity
