Hello Forum,
Hello Mods and Members,
the Silent Installation with this Article https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/ENU/Autodesk-Installation-Basi... works fine for the Civil 3D 2022 Application.
Not for the Plugins/ Addon Installation. The Switches (also for the unzipped File) does not not work.
Can everyone help me with Silent Switches for the Autodesk Storm & Sanitary Analysis and InfrastructurePartsEditor Addons /Plugins?
Many Thanks.
Greetings,
Sebastian
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
The command line parameters for the installer executable can be generated to find all available program options and a short descriptions.
Use the following parameter:
Name Parameter Description of parameter
Help | - h
-- help |
Prints the available program options and a short description for each. |
Also try reviewing the Civil 3d Help guide.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello Natasha,
Many Thanks for your Reply.
Sorry, but No.
The - h or -- h Parameters are not working on Autodesk_SSA_2022.exe or on the unzipped File called "setup.exe"
(Also for InfrastructurePartsEditor.exe).
With these Parameters starts the Programminstallation normally, not with a Help Window or Paramater Zone or similar.
Or for what of the Part of the Installation File, ist the - h or -- h Parameters? The Parameter -q does not Work either. I not understand it.
The Help for Installation of Civil 3D was also not helpfull, i had already checked this in Advance.
Can You help me?
Greetings
Sebastian
I am having the same issue with Autodesk Storm & Sanitary Analysis installer. Anyone has a workaround or solution? thank you
