Good morning,
As an Academic Resource Centre customer, we've downloaded the Autodesk T-Splines plugin for Rhino 5, and obtained the network licence and serial number, which is all activated and running on our Autodesk network licence server.
However, the installer for the T-Splines plugin appears to have some issues.
I tried the version from Academic Resource Centre and the installer from the T-Splines website, both came up with exactly the same errors.
I've also tried to run the setup with a series of switches to batch install an Autodesk product, something like:
setup.exe /t /qb /language en-US /c TSPLINESPLUGINX64: INSTALLDIR="%ProgramFiles%\Autodesk\T-Splines for Rhino" ACADSERIALPREFIX="XXX" ACADSERIALNUMBER="YYYYYYYY" ADLM_PRODKEY="A46G1" ADLM_EULA_COUNTRY="en-US" InstallLevel=5 ACADSTANDALONENETWORKTYPE="3" ACADLICENSESERVERTYPE="Single Server License" ACADLICENSETYPE="Network License" ACADSERVERPATH="serveraddress 000000000000"
This only appears to work if running as a user with admin rights, not for example if as a system user, so deployment with either SCCM or Zenworks would prove to be incorrect. Also an uninstall would still fail for the same reason as above.
Is there any way the installer can be checked and possibly a solution found?
Regards
Warren.
Solved by m_latz. Go to Solution.
I'm not sure if I can help you. But if you upload the installation log from T-Splines installation I can take a look.
The log file is created during the install in the %temp% folder and should have a name like "TSplinesForRhino64.log" or something similiar.
It is also possible that it is something like MSI*.log.
regards
Markus
To analyze I need the full msi log file. If you install under "system context" %temp% is redirected to %systemroot%\temp.
To enable full MSI logging in general, create the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer
"Logging"="voicewarmupx"
"Debug"=dword:00000007
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Trace
"Flags"=dword:00000016
"Level"=dword:00000004
See here for additional infos:
https://support.microsoft.com/en-us/kb/2545723
Then please upload the log files.
regards
Markus
PS: Do not forget to delete the keys after ...
I used the MSI command /L*V to write a verbose log file (which does similar to what you posted), which gave me much more information. Notable are these lines from the install log:
MSI (c) (EC:9C) [12:09:15:059]: PROPERTY CHANGE: Adding Autodesk.156A2FBD_DFC6_4DE0_8EAA_12F01193E0B0 property. Its value is 'C:\ProgramData\Autodesk\'.
MSI (c) (EC:9C) [12:09:15:059]: PROPERTY CHANGE: Adding AdLM.156A2FBD_DFC6_4DE0_8EAA_12F01193E0B0 property. Its value is 'C:\ProgramData\Autodesk\AdLM\'.
MSI (c) (EC:9C) [12:09:15:059]: PROPERTY CHANGE: Adding INSTALLDIR.156A2FBD_DFC6_4DE0_8EAA_12F01193E0B0 property. Its value is 'C:\ProgramData\Autodesk\AdLM\ASR\'.
MSI (c) (EC:9C) [12:09:46:595]: Note: 1: 1314 2: INSTALLDIRadlm
MSI (c) (EC:9C) [12:09:46:595]: Note: 1: 1606 2: INSTALLDIRadlm
Error 1606. Could not access network location INSTALLDIRadlm.
MSI (c) (EC:9C) [12:09:48:431]: Product: Autodesk T-Splines Plug-in for Rhino version 4.0 r11183 (64) -- Error 1606. Could not access network location INSTALLDIRadlm.
MSI error 1314 before 1606 states that the property attempting to be written either is being written to an existing folder or property, or it does not exist.
I've attached the full MSI log.
The path is exactly the same as your screen shot, having checked:
C:\Program Files\Rhinoceros 5 (64-bit)\System\
Okay looks like few custom action are forgotten to place in the "Admin Exec Sequence". The only way to fix this is to create a transformation (.mst) for the original .msi file.
Two options:
regards
Markus
Markus,
Thank you for that. I do suspect though that really Autodesk need to take a look at the installer for this and either:
If you can explain which properties should be in the AdminExecSequence I can use Orca myself to do this (I'm well versed in it)
Regards
Warren.
Okay I try to explain:
I think the problem starts with the property change:
MSI (c) (EC:9C) [12:09:15:044]: Doing action: DIRCA_NEWRETARGETABLEPROPERTY1.D417096D122F4A308076E3294D6E7735
Action 12:09:15: DIRCA_NEWRETARGETABLEPROPERTY1.D417096D122F4A308076E3294D6E7735.
Action start 12:09:15: DIRCA_NEWRETARGETABLEPROPERTY1.D417096D122F4A308076E3294D6E7735.
MSI (c) (EC:9C) [12:09:15:044]: PROPERTY CHANGE: Adding NEWRETARGETABLEPROPERTY1.D417096D122F4A308076E3294D6E7735 property. Its value is 'INSTALLDIRadlm'.
If you check in orca how this property gets his value, you see:
NEWRETARGETABLEPROPERTY1.D417096D122F4A308076E3294D6E7735=[RhinoInstallLocationDefault]adlm
Before, you have an addtional CA in the normal install execute sequence:
SetRhinoInstallLocationDefault (MSI Type 51) which does the following:
RhinoInstallLocationDefault=[INSTALLDIR]
(property name)=(property value)
What I see from your log file is, that the CA "SetRhinoInstallLocationDefault" is never called. So it has the value, as in your error message.
As workaround you can set manually this property. There are also a few other CA's that are not called, but I'm not sure if htey are really required.
I've tried to install interactive as admin and it always worked.
Because I have executed the msi file the same way Autodesk does:
setup.exe runs and creates a temporary .mst file (in %temp% folder). Then calls the .msi with that transformation. So I grabbed that .mst file and modified that. Then you can also run the msi direct with msiexec, or embed in SCCM.
I have attached the grabbed .mst file that you can see what I mean.
If you create an deployment with the setup.exe program (if there is that option) it is the same. Setup.exe gets all information from you and put it into the .mst file. Then calls during the silent install msiexec with the msi and mst.
regards
Markus
Okay, had some time and tried with a Rhino and TSpline test installation. And yes, I also received the InstallDiradlm error.
But as mentioned previously, there was something missing in the sequence table. I add this with a transformation and now I can install completely silent with:
msiexec /i TSplinesForRhino.msi TRANSFORMS="TS.mst" /qn
Uninstall with:
msiexec /X{06A53CDE-94E9-442D-A9C9-03B22BC9CE08} /qn
You can try, what you need is the transformation file attached here. Check what I have modified ....
I have installed in "trial mode", because I have no network license, so you have to adapt some other properties. But your main problem ist solved.
regards
Markus
Markus,
Many thanks for your assistance with this, much appreciated.
Based on the additional properties that you set in the MST transform, I ran through an installation using the setup.exe as admin, so it creates the MSI and MST transform in the %temp% folder and grabbed those from there once I'd added all the network licence information.
I then did a compare with the MST you provided and found out that the only two properties that were missing when the MST was created with the serialisation were the two you added in the InstallSequence UI table:
I added those back in to the MST and re-saved the transform with those changes. Everything is now working correctly and as intended.
However, that does still pose the question of the installer that it should specify those two properties in there originally, or even why there isn't a deployment creation option for its setup, which would have saved time (and indeed would have created the MSI / MST in the same way Autodesk do for other products)
Everything installs correctly, the plugin talk to our Autodesk licence server and it can be uninstalled, so all good. Many many thanks! 🙂
Markus,
One final thing. For the installer to play ball, if you just have the MSI and MST in one folder, I found that it also needed T-SplinesPlug-InforRhinoConfig.pit to be present in the same folder - this is normally in the x64 directory of the downloaded installer.
Not having this file present resulted in an error because it seems to refer to it for some product information.
Regards - and thanks for all your help!
Warren.
Yes, thank's for your remark / confirm.
I supposed, that this file is necessary, because the .pit files contains information for license management / product management.
But I could not try, because I have no license and in "trial mode" it was not necessary.
And thank you for your problem, because it is always a challenge, to find solutions 🙂
regards
Markus
