Revit Server and Windows Server 2016
Message 1 of 8
Hi all,
We are planning to migrate to Windows Server 2016 soon and I would like to know if anyone can tell me if Revit Server 2015, 2016 and 2017 run without any issues on Windows Server 2016?
Thanks in advance
Replies (7)
Message 2 of 8
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Per the system requirements (for 2017), it is not supported but I will tag @Darin.Green, @DarrenP, or @Todd_Rogers for the input just in case they know something that I don't.
Mark Lancaster
Message 3 of 8
DarrenP
i have not personally tried server 2016 with revit server yet
DarrenP
Message 4 of 8
jrobrador19
Good day guys,
I just recently tried to implement Revit Server 2017 in a Windows Server 2016 OS. It worked with the following configurations:
The main difference of server 2016 is that it does not have the Application Server Role. I don't know why but the Application Server features are now distributed to other sections.
Jerous
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
Message 5 of 8
jrobrador19
@Anonymous Please accept as solution if it helps.
Jerous
Jerous Obrador
Message 6 of 8
Sorry guys for the late response. I have been very busy with other things and this test was victim of that.
@Jerous, I will give you solution a try and will report back.
Message 7 of 8
The solution also works for Revit server 2016.
Thanks all
Message 8 of 8
Basam.Yousif
Hello Jerous!
It has been a year and a half since you posted this. I would like to know how well it has been working. Any issues at all? Did you use it for RS 2019? Any updates or gained experience you'd like to share?
