Installation failure for revit
I am trying to install revit 2018 but it keeps failing to install and I'm using windows 10. this is the log file, it fails in the material library
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 === Setup started on LAPTOP-00QJ1HA2 by Bibo_ ===
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 Path_Length: 155
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_wi_en-US
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 Launch
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 CommandLine /PK 829J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/Revit_2018_..."
2017/10/17:11:14:26 Bibo_ LAPTOP-00QJ1HA2 Current Directory C:\Users\Bibo_\AppData\Local\Temp\_AIBD30.tmp
2017/10/17:11:14:28 Bibo_ LAPTOP-00QJ1HA2 === Setup ended ===
2017/10/17:11:14:27 Bibo_ LAPTOP-00QJ1HA2 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:14:27 Bibo_ LAPTOP-00QJ1HA2 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:14:27 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Bibo_\AppData\Local\Temp\_AIBD30.tmp\Setup\RevitSetup.dll
2017/10/17:11:14:27 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/10/17:11:14:28 Bibo_ LAPTOP-00QJ1HA2 PageOpen LaunchDialog
2017/10/17:11:14:33 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Bibo_\AppData\Local\Temp\_AIBD30.tmp\Setup\RevitSetup.dll
2017/10/17:11:14:33 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2018. URLTitle= URLLink=
2017/10/17:11:15:29 Bibo_ LAPTOP-00QJ1HA2 PageOpen LicenseDialog
2017/10/17:11:15:29 Bibo_ LAPTOP-00QJ1HA2 PageOpen ProductInfoDialog
2017/10/17:11:15:29 Bibo_ LAPTOP-00QJ1HA2 PageOpen ProductSelectionDialog2
2017/10/17:11:16:27 Bibo_ LAPTOP-00QJ1HA2 PageOpen FullProgressDialog
2017/10/17:11:16:28 Bibo_ LAPTOP-00QJ1HA2 Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:29 Bibo_ LAPTOP-00QJ1HA2 Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:29 Bibo_ LAPTOP-00QJ1HA2 Download Skipped VCREDIST2005X86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:29 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Bibo_\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/10/17:11:16:34 Bibo_ LAPTOP-00QJ1HA2 Microsoft Visual C++ 2005 Redistributable (x86) return code: 0
2017/10/17:11:16:34 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2017/10/17:11:16:34 Bibo_ LAPTOP-00QJ1HA2 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:34 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Bibo_\AppData\Local\Temp\vcredist_x86_2015.log
2017/10/17:11:16:35 Bibo_ LAPTOP-00QJ1HA2 Microsoft Visual C++ 2015 Redistributable (x86) return code: 1638
2017/10/17:11:16:35 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/10/17:11:16:36 Bibo_ LAPTOP-00QJ1HA2 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:36 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Bibo_\AppData\Local\Temp\vcredist_x64_2015.log
2017/10/17:11:16:36 Bibo_ LAPTOP-00QJ1HA2 Microsoft Visual C++ 2015 Redistributable (x64) return code: 1638
2017/10/17:11:16:36 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/10/17:11:16:37 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314ATLX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:37 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:37 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/10/17:11:16:38 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314MFCX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:38 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:39 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/10/17:11:16:39 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314CRTX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:39 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:40 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/10/17:11:16:41 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314OPENMPX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:41 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:42 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/10/17:11:16:42 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314ATLX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:42 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:42 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/10/17:11:16:43 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314MFCX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:43 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:44 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/10/17:11:16:45 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314CRTX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:45 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:46 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/10/17:11:16:46 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314OPENMPX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:46 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:16:47 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/10/17:11:16:48 Bibo_ LAPTOP-00QJ1HA2 Download Skipped DOTNET462 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:16:48 Bibo_ LAPTOP-00QJ1HA2 Installing .NET Framework Runtime 4.6.2: "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\NET\462\wcu\dotnetfx462_full_x86_x64.exe" /q /norestart
2017/10/17:11:17:12 Bibo_ LAPTOP-00QJ1HA2 .NET Framework Runtime 4.6.2 return code: 0
2017/10/17:11:17:12 Bibo_ LAPTOP-00QJ1HA2 Install .NET Framework Runtime 4.6.2 Failed Failure is ignored, Result=1603
2017/10/17:11:17:12 Bibo_ LAPTOP-00QJ1HA2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:11:17:16 Bibo_ LAPTOP-00QJ1HA2 Install FaroSDK Succeeded
2017/10/17:11:17:16 Bibo_ LAPTOP-00QJ1HA2 Download Skipped RCL http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:11:17:16 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® Content Libraries 2018: TRANSFORMS=":en-us.mst;C:\Users\Bibo_\AppData\Local\Temp\_AIBD30.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:00:59 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® Content Libraries 2018 Succeeded
2017/10/17:12:00:59 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft SQL Server 2014 (SP1) Express: IACCEPTSQLLOCALDBLICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:01:12 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/10/17:12:01:12 Bibo_ LAPTOP-00QJ1HA2 Download Skipped RVT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:01:12 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018: TRANSFORMS=":en-us.mst;:all.mst;C:\Users\Bibo_\AppData\Local\Temp\_AIBD30.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:23 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 Succeeded
2017/10/17:12:03:23 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk Workflows 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:24 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Workflows 2018 Succeeded
2017/10/17:12:03:24 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Collaboration for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:29 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Collaboration for Revit® 2018 Succeeded
2017/10/17:12:03:29 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Personal Accelerator for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:31 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Personal Accelerator for Revit® 2018 Succeeded
2017/10/17:12:03:31 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Batch Print for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:34 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Batch Print for Revit® 2018 Succeeded
2017/10/17:12:03:34 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® eTransmit for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:36 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® eTransmit for Revit® 2018 Succeeded
2017/10/17:12:03:36 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Model Review for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:39 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Model Review for Revit® 2018 Succeeded
2017/10/17:12:03:39 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Worksharing Monitor for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:41 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Worksharing Monitor for Revit® 2018 Succeeded
2017/10/17:12:03:41 Bibo_ LAPTOP-00QJ1HA2 Download Skipped CMILL2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:03:41 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk Material Library 2018 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:49 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Material Library 2018 - Low Image Library Succeeded
2017/10/17:12:03:49 Bibo_ LAPTOP-00QJ1HA2 Download Skipped IRONPYTHON http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:03:49 Bibo_ LAPTOP-00QJ1HA2 Installing IronPython-2.7.3.msi: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:03:53 Bibo_ LAPTOP-00QJ1HA2 Install IronPython-2.7.3.msi Succeeded
2017/10/17:12:03:53 Bibo_ LAPTOP-00QJ1HA2 Download Skipped DirectX http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:03:53 Bibo_ LAPTOP-00QJ1HA2 Installing DXSETUP.exe: "C:\Autodesk\WI\Autodesk Revit 2018\x64\Tools\DirectX\DXSETUP.exe" /silent
2017/10/17:12:03:58 Bibo_ LAPTOP-00QJ1HA2 DXSETUP.exe return code: 0
2017/10/17:12:03:58 Bibo_ LAPTOP-00QJ1HA2 Install DXSETUP.exe Succeeded
2017/10/17:12:03:58 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® DYNAMOCORE Add-in for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:04:01 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® DYNAMOCORE Add-in for Revit® 2018 Succeeded
2017/10/17:12:04:02 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{1EBADAEA-1A0F-40E3-848C-0DD8C5E5A10D},DXSETUP.exe,{AEC2A178-12F1-4B42-B277-E7C395FC771C},;;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:04:10 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018 Succeeded
2017/10/17:12:04:10 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® FormIt Add-in for Revit® 2018: INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:04:12 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® FormIt Add-in for Revit® 2018 Succeeded
2017/10/17:12:04:12 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2018\Revit MEP Imperial Content\Preview\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:04:16 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial Succeeded
2017/10/17:12:04:16 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2018\Revit MEP Metric Content\Preview\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:04:21 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric Succeeded
2017/10/17:12:04:22 Bibo_ LAPTOP-00QJ1HA2 Download Play CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:04:41 Bibo_ LAPTOP-00QJ1HA2 Download Error CMILM2018 Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:04:50 Bibo_ LAPTOP-00QJ1HA2 Download Aborted CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:04:50 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Material Library 2018 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2017/10/17:12:04:56 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric Succeeded
2017/10/17:12:05:02 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial Succeeded
2017/10/17:12:05:02 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® FormIt Add-in for Revit® 2018 Succeeded
2017/10/17:12:05:07 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018 Succeeded
2017/10/17:12:05:10 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® DYNAMOCORE Add-in for Revit® 2018 Succeeded
2017/10/17:12:05:10 Bibo_ LAPTOP-00QJ1HA2 Rollback DXSETUP.exe Failed Failure is ignored, Result=1619
2017/10/17:12:05:14 Bibo_ LAPTOP-00QJ1HA2 Rollback IronPython-2.7.3.msi Succeeded
2017/10/17:12:05:19 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk Material Library 2018 - Low Image Library Succeeded
2017/10/17:12:05:20 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Worksharing Monitor for Revit® 2018 Succeeded
2017/10/17:12:05:22 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Model Review for Revit® 2018 Succeeded
2017/10/17:12:05:23 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® eTransmit for Revit® 2018 Succeeded
2017/10/17:12:05:25 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Batch Print for Revit® 2018 Succeeded
2017/10/17:12:05:25 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Personal Accelerator for Revit® 2018 Succeeded
2017/10/17:12:05:27 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Collaboration for Revit® 2018 Succeeded
2017/10/17:12:05:27 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk Workflows 2018 Succeeded
2017/10/17:12:06:16 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 Succeeded
2017/10/17:12:06:26 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/10/17:12:06:45 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® Content Libraries 2018 Succeeded
2017/10/17:12:06:46 Bibo_ LAPTOP-00QJ1HA2 Rollback FaroSDK Succeeded
2017/10/17:12:06:47 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/10/17:12:06:47 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/10/17:12:06:48 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/10/17:12:06:48 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/10/17:12:06:49 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/10/17:12:06:50 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/10/17:12:06:50 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/10/17:12:06:51 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/10/17:12:06:51 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2017/10/17:12:06:51 Bibo_ LAPTOP-00QJ1HA2 PageOpen InstallCompleteDialog
2017/10/17:12:14:51 Bibo_ LAPTOP-00QJ1HA2 === Setup ended ===
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 === Setup started on LAPTOP-00QJ1HA2 by Bibo_ ===
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 Path_Length: 155
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 Current Directory C:\Autodesk\Revit_2018_G1_Win_64bit_wi_en-US
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 Launch
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 CommandLine /PK 829J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/Revit_2018_..."
2017/10/17:12:16:08 Bibo_ LAPTOP-00QJ1HA2 Current Directory C:\Users\Bibo_\AppData\Local\Temp\_AI3B2A.tmp
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 === Setup ended ===
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Bibo_\AppData\Local\Temp\_AI3B2A.tmp\Setup\RevitSetup.dll
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/10/17:12:16:09 Bibo_ LAPTOP-00QJ1HA2 PageOpen LaunchDialog
2017/10/17:12:16:13 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Bibo_\AppData\Local\Temp\_AI3B2A.tmp\Setup\RevitSetup.dll
2017/10/17:12:16:13 Bibo_ LAPTOP-00QJ1HA2 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2018. URLTitle= URLLink=
2017/10/17:12:16:57 Bibo_ LAPTOP-00QJ1HA2 PageOpen LicenseDialog
2017/10/17:12:16:57 Bibo_ LAPTOP-00QJ1HA2 PageOpen ProductInfoDialog
2017/10/17:12:16:57 Bibo_ LAPTOP-00QJ1HA2 PageOpen ProductSelectionDialog2
2017/10/17:12:17:05 Bibo_ LAPTOP-00QJ1HA2 PageOpen FullProgressDialog
2017/10/17:12:17:06 Bibo_ LAPTOP-00QJ1HA2 Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:07 Bibo_ LAPTOP-00QJ1HA2 Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:07 Bibo_ LAPTOP-00QJ1HA2 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:07 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Bibo_\AppData\Local\Temp\vcredist_x86_2015.log
2017/10/17:12:17:07 Bibo_ LAPTOP-00QJ1HA2 Microsoft Visual C++ 2015 Redistributable (x86) return code: 1638
2017/10/17:12:17:07 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/10/17:12:17:08 Bibo_ LAPTOP-00QJ1HA2 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:08 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Bibo_\AppData\Local\Temp\vcredist_x64_2015.log
2017/10/17:12:17:08 Bibo_ LAPTOP-00QJ1HA2 Microsoft Visual C++ 2015 Redistributable (x64) return code: 1638
2017/10/17:12:17:08 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/10/17:12:17:09 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314ATLX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:09 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:10 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/10/17:12:17:10 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314MFCX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:10 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:11 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/10/17:12:17:11 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314CRTX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:11 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:12 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/10/17:12:17:13 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314OPENMPX86 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:13 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:13 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/10/17:12:17:14 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314ATLX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:14 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:14 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/10/17:12:17:15 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314MFCX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:15 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:16 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/10/17:12:17:16 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314CRTX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:16 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:17 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/10/17:12:17:18 Bibo_ LAPTOP-00QJ1HA2 Download Skipped KB958314OPENMPX64 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:18 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:18 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/10/17:12:17:19 Bibo_ LAPTOP-00QJ1HA2 Download Skipped DOTNET462 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:19 Bibo_ LAPTOP-00QJ1HA2 Installing .NET Framework Runtime 4.6.2: "C:\Autodesk\WI\Autodesk Revit 2018\3rdParty\NET\462\wcu\dotnetfx462_full_x86_x64.exe" /q /norestart
2017/10/17:12:17:42 Bibo_ LAPTOP-00QJ1HA2 .NET Framework Runtime 4.6.2 return code: 0
2017/10/17:12:17:42 Bibo_ LAPTOP-00QJ1HA2 Install .NET Framework Runtime 4.6.2 Failed Failure is ignored, Result=1603
2017/10/17:12:17:42 Bibo_ LAPTOP-00QJ1HA2 Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:12:17:45 Bibo_ LAPTOP-00QJ1HA2 Install FaroSDK Succeeded
2017/10/17:12:17:45 Bibo_ LAPTOP-00QJ1HA2 Download Skipped RCL http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:12:17:45 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® Content Libraries 2018: TRANSFORMS=":en-us.mst;C:\Users\Bibo_\AppData\Local\Temp\_AI3B2A.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:07:02 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® Content Libraries 2018 Succeeded
2017/10/17:13:07:02 Bibo_ LAPTOP-00QJ1HA2 Installing Microsoft SQL Server 2014 (SP1) Express: IACCEPTSQLLOCALDBLICENSETERMS=YES ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:07:14 Bibo_ LAPTOP-00QJ1HA2 Install Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/10/17:13:07:14 Bibo_ LAPTOP-00QJ1HA2 Download Skipped RVT http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:07:14 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018: TRANSFORMS=":en-us.mst;:all.mst;C:\Users\Bibo_\AppData\Local\Temp\_AI3B2A.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:33 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 Succeeded
2017/10/17:13:08:33 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk Workflows 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:34 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Workflows 2018 Succeeded
2017/10/17:13:08:34 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Collaboration for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:37 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Collaboration for Revit® 2018 Succeeded
2017/10/17:13:08:37 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Personal Accelerator for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:39 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Personal Accelerator for Revit® 2018 Succeeded
2017/10/17:13:08:39 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Batch Print for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:41 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Batch Print for Revit® 2018 Succeeded
2017/10/17:13:08:41 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® eTransmit for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:43 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® eTransmit for Revit® 2018 Succeeded
2017/10/17:13:08:43 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Model Review for Revit® 2018: TRANSFORMS=":en-us.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:45 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Model Review for Revit® 2018 Succeeded
2017/10/17:13:08:45 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Worksharing Monitor for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:47 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Worksharing Monitor for Revit® 2018 Succeeded
2017/10/17:13:08:47 Bibo_ LAPTOP-00QJ1HA2 Download Skipped CMILL2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:08:47 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk Material Library 2018 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{7847611E-92E9-4917-B395-71C91D523104},;;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:55 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Material Library 2018 - Low Image Library Succeeded
2017/10/17:13:08:55 Bibo_ LAPTOP-00QJ1HA2 Download Skipped IRONPYTHON http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:08:55 Bibo_ LAPTOP-00QJ1HA2 Installing IronPython-2.7.3.msi: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:08:58 Bibo_ LAPTOP-00QJ1HA2 Install IronPython-2.7.3.msi Succeeded
2017/10/17:13:08:59 Bibo_ LAPTOP-00QJ1HA2 Download Skipped DirectX http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:08:59 Bibo_ LAPTOP-00QJ1HA2 Installing DXSETUP.exe: "C:\Autodesk\WI\Autodesk Revit 2018\x64\Tools\DirectX\DXSETUP.exe" /silent
2017/10/17:13:09:01 Bibo_ LAPTOP-00QJ1HA2 DXSETUP.exe return code: 0
2017/10/17:13:09:01 Bibo_ LAPTOP-00QJ1HA2 Install DXSETUP.exe Succeeded
2017/10/17:13:09:01 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® DYNAMOCORE Add-in for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:09:04 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® DYNAMOCORE Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:04 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{1EBADAEA-1A0F-40E3-848C-0DD8C5E5A10D},DXSETUP.exe,{AEC2A178-12F1-4B42-B277-E7C395FC771C},;;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:09:12 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:12 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® FormIt Add-in for Revit® 2018: INSTALLDIR="C:\Program Files\Autodesk\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:09:14 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® FormIt Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:14 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2018\Revit MEP Imperial Content\Preview\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:09:18 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial Succeeded
2017/10/17:13:09:18 Bibo_ LAPTOP-00QJ1HA2 Installing Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2018" SETUP_PACKAGECODE={7346B4A0-1800-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={89DB791F-E258-4EB0-AB76-DC1C184D93A6} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2018" INSTALLDIR="C:\Program Files_MSISETUP_{2956EBA1-9B5A-4679-8618-357136DA66CA}\Autodesk\Fabrication 2018\Revit MEP Metric Content\Preview\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/10/17:13:09:23 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric Succeeded
2017/10/17:13:09:24 Bibo_ LAPTOP-00QJ1HA2 Download Play CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:09:30 Bibo_ LAPTOP-00QJ1HA2 Download Error CMILM2018 Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:09:34 Bibo_ LAPTOP-00QJ1HA2 Download Aborted CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:09:34 Bibo_ LAPTOP-00QJ1HA2 Install Autodesk Material Library 2018 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2017/10/17:13:09:41 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 MEP Fabrication Configuration - Metric Succeeded
2017/10/17:13:09:47 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 MEP Fabrication Configuration- Imperial Succeeded
2017/10/17:13:09:48 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® FormIt Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:52 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® DYNAMOREVIT™ Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:55 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® DYNAMOCORE Add-in for Revit® 2018 Succeeded
2017/10/17:13:09:55 Bibo_ LAPTOP-00QJ1HA2 Rollback DXSETUP.exe Failed Failure is ignored, Result=1619
2017/10/17:13:09:59 Bibo_ LAPTOP-00QJ1HA2 Rollback IronPython-2.7.3.msi Succeeded
2017/10/17:13:10:04 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk Material Library 2018 - Low Image Library Succeeded
2017/10/17:13:10:06 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Worksharing Monitor for Revit® 2018 Succeeded
2017/10/17:13:10:07 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Model Review for Revit® 2018 Succeeded
2017/10/17:13:10:09 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® eTransmit for Revit® 2018 Succeeded
2017/10/17:13:10:10 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Batch Print for Revit® 2018 Succeeded
2017/10/17:13:10:11 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Personal Accelerator for Revit® 2018 Succeeded
2017/10/17:13:10:12 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Collaboration for Revit® 2018 Succeeded
2017/10/17:13:10:13 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk Workflows 2018 Succeeded
2017/10/17:13:11:02 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® 2018 Succeeded
2017/10/17:13:11:07 Bibo_ LAPTOP-00QJ1HA2 Download User Play CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:11:12 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft SQL Server 2014 (SP1) Express Succeeded
2017/10/17:13:11:20 Bibo_ LAPTOP-00QJ1HA2 Download Error CMILM2018 Unknown error! http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:11:24 Bibo_ LAPTOP-00QJ1HA2 Download Aborted CMILM2018 http://edutrial.autodesk.com/NET18SWDLD/2018/RVT/89DB791F-E258-4EB0-AB76-DC1C184D93A6/WI/{1BC69F7B-C...
2017/10/17:13:11:31 Bibo_ LAPTOP-00QJ1HA2 Rollback Autodesk® Revit® Content Libraries 2018 Succeeded
2017/10/17:13:11:32 Bibo_ LAPTOP-00QJ1HA2 Rollback FaroSDK Succeeded
2017/10/17:13:11:32 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2017/10/17:13:11:33 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/10/17:13:11:34 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/10/17:13:11:34 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/10/17:13:11:35 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/10/17:13:11:35 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/10/17:13:11:36 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/10/17:13:11:37 Bibo_ LAPTOP-00QJ1HA2 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Your download is failing due to the method you're using.
Download and install per:
1.  Clean out your personal temp (%temp%) folder.  Make sure you have full admin rights, set Windows UAC to never notify and if possible disable your Anti-Virus/Malware scanning utilities. Also the download should occur over a hard wired connection to the Internet and not over WIFI.
2. Access the Autodesk Virtual Agent and follow the download links to your product.
3. Download all of the parts (some applications only have a single part to download) for your product first. This means save each part to your hard drive.  Do not continue until all of the parts have fully downloaded.
4. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
5. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
6. Once the extraction is finished, the installation will automatically start.
7. Follow the installation steps for your product.  At this point you could cancel the installation or create a deployment.
However if the installation does fail using this method, please post your installation log file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Good luck on your installation and report back on your progress.
Mark Lancaster
Good evening, I have the same problem with the revit 2018 installation. Please look at the attachments doc.
I have try to install for 3 times and it's allway aborted.
Tanks
Mark.Lancaster
@Anonymous
Your download is simply failing due to the method you're using.
There's a couple of ways to properly download and install your Autodesk product to your machine.  Please review this article and the solution it provides.
If the installation does fail using the preferred methods, please post your installation log file here so we can review it.
Mark Lancaster
