Greetings everyone,
I am running Windows 11 on my Macbook parallel and have been attempting to install Revit 2025.
The install usually reaches around 9%, after which it randomly cancels and gives an 'Error 10".
I have tried all attempts at updating windows, running commands in terminal and speaking with Autodesk support staff who unfortunately have done little to help.
I was told by a Live Agent that my case would need to be moved to the technical department and within 2-3 days I would receive an email, which has of course not happened. they have only referred me to the forum where people have previously discussed this error, however these have not seemed to work.
If anyone has overcome this issue or a similar one, do let me know!
Thanks.
Greetings everyone,
Thanks.
Solved by mdavis22569. Go to Solution.
Hi @ssant192
Thanks a lot for posting your question to the forums! Can you try the below?
To workaround this issue perform the following steps :
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Hi @ssant192
Jonathan Hand
I have tried this before as stated and in terminal it tells me 'no application knows how to open URL'.
Yes, this also did not help
@ssant192 wrote:...I was told by a Live Agent that my case would need to be moved to the technical department and within 2-3 days I would receive an email, which has of course not happened....
Keep calling. Then again. and again.
@ssant192 wrote:...I am running Windows 11 on my Macbook parallel...
Try Parallels Support, and the Parallels User Forums in the interim.
Hi @ssant192
Sometimes the 2-3 days a bit longer. Especially around holidays.
Quick question, how did you download it for installation? Was it the Webinstaller or was it the multiple download?
Can you try this offline installer:
P1:
https://efulfillment.autodesk.com/NetSWDLD/ODIS/prd/2025/RVT/686CE2A3-7C33-3AD5-806A-75A6E648117F/SF...
P2:
Hi @ssant192
P1:
P2:
The first link helped me and the install worked. Thank you!
Hi there, I'm also having the same issues as OP has. I tried walking through each of these steps with no success. Is there any other recommendations you fine folks have?
@u0782123 wrote:Hi there, I'm also having the same issues as OP has. I tried walking through each of these steps with no success. Is there any other recommendations you fine folks have?
Log into your PC as an all new never-seen-before user with full admin control, then try it again.
OR... try it on a second PC.
After that... you'll need to find an experienced IT group to tackle it all for you.
HTH
HTH
Need help with similar problem.
I am trying to install Revit 2025 on VMware Fusion 13 Windows 11 VM and I am also getting the same Error 10.
Hi Johnathan,
I have a Macbook pro 2023 with M2 pro chip and i cannot also install Revit as it is going up to only 9% and then saying "error 10"... I need to sort this out asap for a university assignment. How can I get help on this?
Please
Hi Johnathan,
Please
Hey, were you able to try the links @mdavis22569 provided?
The first one worked for me
I tried downloading directly from autodesk, then tried these links, but it does not work, i get the same error message.
@juliusgUFDC7 My links are giving you an issue too?
Can you try deleting all of the downloads.
Delete the C\Autodesk data, files, folders relating to Revit 2025
Clean out the %temp% folder for Windows.
Make sure the anti-Virus is off.
Please download my links again. From there, extract them to your C:\Autodesk as prompted. Let us know what happens please
i have the same issue and the link doesn't work any other suggestions?
were you able to install it?
@mdavis22569 I tried everything you suggested, but I get the same Error 10. Reinstalled windows arm several times, tried these links on freshly installed windows 11s, but it also didn't help.
I am using VMware, not Parallels, maybe that's the main issue
I would look at that .. and you pointed something out:
When you mentioned: Windows Arm....
Hi! The second link worked to me.
But I still need 2024 version. Do you have it ?
Thank a lot
Thank a lot
