Hi folks --
Like so many others, I'm having a really hard time wrapping my head around the new installers. I have network licenses for Revit 2022, which isn't showing up in my list for creating a custom installer, so I assume I have to use the old way of downloading the installer manually to create the install package. However, the new installer doesn't give the option to create an administrative image. Instead, I found instructions for a silent install for Revit 2022, which is basically just to run "setup.exe -q". That "works" to install it, but I can't figure out how to apply the licensing info. The environment variable (ADSK_FLEX_LICENSEFILE) is set to the correct port@server, and works for all the rest of the older Autodesk products installed. The silent installer completes without issue, but then on first launch, comes up asking for license info. If I choose Network license, and put in the port@server, it then launches fine as expected. I tried to copy a few files from a working install ...
Am I missing something? Should Revit be available in the new custom installer web interface, and it just didn't get wired up to my account properly?
