Revit 2022 Silent Install with licensing info
helpdesk
helpdesk
Hi folks --
Like so many others, I'm having a really hard time wrapping my head around the new installers.  I have network licenses for Revit 2022, which isn't showing up in my list for creating a custom installer, so I assume I have to use the old way of downloading the installer manually to create the install package.  However, the new installer doesn't give the option to create an administrative image.  Instead, I found instructions for a silent install for Revit 2022, which is basically just to run "setup.exe -q".  That "works" to install it, but I can't figure out how to apply the licensing info.  The environment variable (ADSK_FLEX_LICENSEFILE) is set to the correct port@server, and works for all the rest of the older Autodesk products installed.  The silent installer completes without issue, but then on first launch, comes up asking for license info.  If I choose Network license, and put in the port@server, it then launches fine as expected.  I tried to copy a few files from a working install ...
Am I missing something?  Should Revit be available in the new custom installer web interface, and it just didn't get wired up to my account properly?
m_latz
Read the post from @TravisNave :
Solved: How to reset Autodesk 2022 Licensing - Update! - Autodesk Community - Subscription, Installa...
This allows you to change the license method / license data after installation.
regards
Markus
helpdesk
This worked!  Not sure why, but I had to add a 60 second wait, then run that, then another 60 second wait, and then run it again (after waiting for setup.exe -q to complete).  I'm still pretty sure it's not the "correct" way, but until Autodesk can settle on a single installation method that works reliably, at least this gets the application on my lab computers and sets the licensing info correctly.
Thanks for pointing it out!
