Problem installing Inventor 2021
Message 3 of 22
Ive been trying to install inventor for a while now but every time something goes wrong. First I tryed to change the disk for instalation but it didnt let me do it, and I didnt have enough disk space on my C drive. So I maneged to free some space but erros kept occuring so i tryed to do a clean uninstall of every autodesk related folders. Even After that when I try installing Inventor I get to a point where the set up doesnt let me install the program and i dont know why. As you can see from the image it says it requires less space then i have available but still doesent let me install or change the install location.
Replies (21)
Message 1 of 22
Apreciate any help, thanks!
Message 2 of 22
SBix26
The green check marks and the message in blue to the left indicate that those products are already installed.  You may have to try your complete uninstall again.  Also, you may try posting this in the Installation & Licensing Forum, where the experts in installation issues hang out.
Sam B
Inventor Pro 2021.1 | Windows 10 Home 2004
LinkedIn
Message 4 of 22
Thanks for the reply! I posted it where you told me to. And I saw that it said it was installed but i couldnt find the program anywhere.
Message 5 of 22
bradeneuropeArthur
Did you remove something manually by deleting inventor.
Because removing a program only works if removed correctly, but not by deleting files!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 6 of 22
Hello, @bradeneuropeArthur
I followed a youtube tutorial and did delete a lot of things manually, including some hidden folders.
Link for the tutorial: https://youtu.be/xnUH_GxrFBw
Message 7 of 22
bradeneuropeArthur
Did you uninstall the program via the Control Panel and Add and Remove programs?
It seems that the program is not correctly uninstalled.
Could you upload a screenshot of the Control Panel and Add and Remove programs?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 22
I didnt try the uninstall again yet. Now the Inventor shortcut appears in the desktop but it wont open.
Message 9 of 22
bradeneuropeArthur
Are you able to restore your system to a restore point before the removal of the software or a point where the system is clean?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 22
What wold I have to do for that? Reset my pc to factory new?
Message 11 of 22
leowarren34
Hi @Anonymous,
Have you tried running Inventor?  - The blue panes next to each component are indicating that they are already installed which would explain why you can't install them.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 12 of 22
bradeneuropeArthur
No!
User system Restore and store your machine to an earlier point like yesterday or the day before!
Type/search System Restore and you will find out how it works.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 22
Hello, @leowarren34
At first I couldnt find the launcher for inventor but when i restarted the PC  it appeard. But still, when I try to run it nothing happens.
Message 14 of 22
Ok! So the Idea is to restore the system to a point where I didnt have the program?
Message 15 of 22
bradeneuropeArthur
That will also be ok.
But better is to where you had the program but before un-install.
Then you need to un-install it correctly
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 22
Understood. Ill try that and tell you what happens. Thanks!
Message 17 of 22
So, it seems that I needed to have set a restore point before I tryed to uninstall, now its too late for that. Any other ideas for what I can do?
Message 18 of 22
Try these steps for uninstalling the software, note you may need to use the microsoft tool mentioned at the end of the article: https://clintbrown.co.uk/2020/04/16/autodesk-uninstall-tool/
When you are ready to reinstall, follow these steps exactly: https://clintbrown.co.uk/2020/04/16/successfully-installing-your-autodesk-software/
Message 19 of 22
Hi, @Anonymous
I tryed those steps and it was working but I found out I still dont have enough space in my C drive. Do you have any idea of how I can install Inventor on my D drive or something else?
Thanks for the help!
Message 20 of 22
Yes, you can install it on your 😧 Drive, as long as "D" is not a removable drive. You should empty your temp folders on your C :drive
In the istaller, change the path to D:\
