Solved by Mark.Lancaster. Go to Solution.
jessica.bramwell
As long as the license is a commerical license then you can sell your assets as you see fit.
However I'm not a Maya user/expert so the LT version may have limitations that the full version has. I would strongly suggest (if not already) that you do a side by side comparision of the product before investing. I've seen too many times where someone purchases the LT version becuase its cheaper and then later on realizes it doesn't meet their needs due to its limitations.
Mark Lancaster
& Autodesk Services MarketPlace Provider
