Installation & Licensing
Maya 2018, can't enter serial number
8 REPLIES 8
Message 1 of 9
4291 Views, 8 Replies
Hello dear Maya-users,
please help me. I can't enter my serial number to run maya on my MacBook and I haven't found a solution for my problem jet.
This is the error message which appears:
Thank you
Thank you
Tags (2)
8 REPLIES 8
Message 2 of 9
lynn_zhang
lynn_zhang
Hi @rockbarin Welcome to the Community!
Could you try the solution in this link: Unable to intialize adlm: Internal Error Message:  Error Code: <-104> ? Hope it helps.
Lynn Zhang
Lynn Zhang
Message 3 of 9
lynn_zhang
in reply to: lynn_zhang
lynn_zhang
Hi @rockbarin
Have you tried the solution to fix the error? Hope you were able to activate and run your Maya 2018. Let us know if you still need help!
Lynn Zhang
Hi @rockbarin
Lynn Zhang
Message 4 of 9
Hello, no, sorry. I'm struggeling with the first step. I can't find the .data file to delete.
Message 5 of 9
lynn_zhang
lynn_zhang
Hi @rockbarin
Could you try and delete the following folders?
/Library/Preferences/Flexnet Publisher/FLEXnet
/Library/Application Support and delete the Flexnet Publisher
/Library/Frameworks/Adlm.framework
/Library/Application Support/Autodesk/Adlm
/Library/Application\ Support/Autodesk/ADUT
See the steps in Remove Autodesk Licensing Information. After you delete them, try reinstalling the product and see if it works.
Lynn Zhang
Hi @rockbarin
Lynn Zhang
Message 6 of 9
mdavis22569
mdavis22569
Deleted didn't see it was Mac. Sorry
Mike Davis
Mike Davis
Message 7 of 9
mdavis22569
in reply to: mdavis22569
mdavis22569
.................................delete
Mike Davis
Mike Davis
Message 8 of 9
I am so sorry but I am still struggling. in Library/Preferences there is no Flexnet Folder 😞 And also when I search for Flexnet, I can't find it.
Message 9 of 9
natasha.l
natasha.l
Hello @Anonymous.
Please be sure to show hidden folders on your Mac. Then follow the steps outlined in this article Reset/Remove Autodesk Licensing Information.
If this does not resolve it conduct a Clean Uninstall of the previous installation attempt & use the MSfixitTool to complete it & reinstall using the Browser Download Method in your Autodesk Account, following the steps in the post's solution.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Hello @Anonymous.
Administrator Productivity
