Hello dear Maya-users,
please help me. I can't enter my serial number to run maya on my MacBook and I haven't found a solution for my problem jet.
This is the error message which appears:
Thank you
Thank you
Solved by natasha.l. Go to Solution.
Hi @rockbarin Welcome to the Community!
Could you try the solution in this link: Unable to intialize adlm: Internal Error Message: Error Code: <-104> ? Hope it helps.
Hi @rockbarin
Have you tried the solution to fix the error? Hope you were able to activate and run your Maya 2018. Let us know if you still need help!
Hi @rockbarin
Hi @rockbarin
Could you try and delete the following folders?
/Library/Preferences/Flexnet Publisher/FLEXnet
/Library/Application Support and delete the Flexnet Publisher
/Library/Frameworks/Adlm.framework
/Library/Application Support/Autodesk/Adlm
/Library/Application\ Support/Autodesk/ADUT
See the steps in Remove Autodesk Licensing Information. After you delete them, try reinstalling the product and see if it works.
Hi @rockbarin
.................................delete
Hello @Anonymous.
Please be sure to show hidden folders on your Mac. Then follow the steps outlined in this article Reset/Remove Autodesk Licensing Information.
If this does not resolve it conduct a Clean Uninstall of the previous installation attempt & use the MSfixitTool to complete it & reinstall using the Browser Download Method in your Autodesk Account, following the steps in the post's solution.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous.
Natasha
Helpful Links:
