Hi everyone!
I'm currently studying and also training at a company which uses Maya. To get up to speed, I'm using the educational license for Maya 2017 on OS X El Capita, which I see no longer has mentalray. I have some scenes using mentalray shaders and I just can't get the plugin to load/autoload after downloading from nVidia.
After reading around the web, I read there's an update 1 or 2 for Mac Maya, which should fix the issue but I can't seem to find it on the downloads page - only for Windows.
If it's not available, can I uninstall Maya 2017, install 2015 and also have 2017 installed at the same time?
Many thanks for any help!
Here's the error message:
// Error: line 1: dlopen(/Applications/NVIDIA Corporation/mentalray-3.14-for-Maya-2017/plug-ins/Mayatomr.bundle, 1): Library not loaded: @executable_path/libsynColor.2017.0.69.dylib Referenced from: /Applications/NVIDIA Corporation/mentalray-3.14-for-Maya-2017/plug-ins/Mayatomr.bundle Reason: image not found (Mayatomr)
Hi everyone!
Solved by natasha.l. Go to Solution.
Hello @rezon71,
Welcome to the forum. You can apply the updates from your Autodesk Account.
Please let me know how it goes. Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @rezon71,
Natasha
Helpful Links:
Hi natashal84!
Thank you for the kind welcome!
I was at that page earlier and only saw updates for Windows and older Mac updates for 2015 mentalray. I'm wondering if there might not be an update for the Mac yet?
Many thanks!
Hi natashal84!
Many thanks!
Hello @rezon71,
Have you checked with Nvidia to see what the system requirements are for installing the plug-in?
Located at the bottom of the page: http://www.nvidia.com/object/nvidia-mental-ray-products.html
Thank you.
Natasha
Helpful Links:
Hello @rezon71,
Thank you.
Natasha
Helpful Links:
Aha! Thank you for that! I did check it but failed to notice the Cuda 8 part. The mac seems fine but will need to see about Cuda 8.
That's brill. Thank you so much!
Hello @rezon71,
No problem, glad it was of help to you. Let us know how it turns out.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Helpful Links:
Hello @rezon71,
Natasha
Helpful Links:
Going to try it this weekend when I get the chance and here's hoping! If it doesn't work, I'll just install 2015 for this one model and still have 2017 at work. Thanks again and much appreciated.
