Installation & Licensing
LTU Follies: 2017 Edition
1 REPLY 1
kolsen
238 Views, 1 Reply
I'm running 3ds Max 2017 on a windows 10 partition on an iMac 5K. At least I was running 3ds Max 2017. Then I used the LTU to export the license and did the major windows 10 upgrade that system wanted me to do. Then I went to import the license, but the LTU is telling me the system date and time is not set correctly. The first time it was true, but I have reset the system date and time and now they are correct but the LTU is giving me the same message.
Any ideas? I can't work with the 3ds Max software I paid for because of this bizarre issue. Thanks in advance.
1 REPLY 1
dgorsman
in reply to: kolsen
Just activate the software.  If the automatic activation system complains you've done that too many times, use the manual activation process.
Administrator Productivity
