Installation & Licensing
licenties755HT
190 Views, 3 Replies
Licenties
Tags (1)
3 REPLIES 3
DarrenP
in reply to: licenties755HT
this isn't an error: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Device-limit-reach...
DarrenP
You have all 3 using the same license:
@bouwbedrijfbaken.nl
If you have 3 licenses you need to assign ALL 3 to each user.  Not having them all use the same sign in. Has to be their own,
https://www.autodesk.com/support/account/admin/users/add-remove-users
Mike Davis
It seems you're trying to let 3 different people use a single license which is against the licensing agreement.
Be careful because Autodesk will randomly or on purpose send an audit message to evaluate your environment.  If caught using the software as different people, you'll be charged for the 2 additional users and fines and fees.
If you are the person using all 3 systems, then there shouldn't be an issue to pause one of the others so you can continue working.  Can you provide more details for what you're trying to accomplish here?
If this information was helpful, please consider using the Accept Solution
Administrator Productivity
