Installation & Licensing
jorgeluizQ37J5
128 Views, 1 Reply
License Server Exchange
Bom dia Senhores,
Possuo 2 licenças da Autodesk para ser instalada em REDE.
Foi gerada uma chave para ativação no modo "Servidor único" onde foi instalada no computador.
preciso gerar uma nova chave para o novo servidor pois o antigo foi dissubstituído.
Ao tenar gerar a nova chave me deparo com a seguinte mensagem informando que já foi gerada uma chave para as licenças.
Preciso que esta chave seja excluída para que assim eu consiga gerar a nova chave.
1 REPLY 1
@jorgeluizQ37J5
This is an English Speaking forum and when your info is translated we see this
Good morning gentlemen,
I have 2 licenses of Autodesk to be installed in NETWORK.
An activation key was generated in "Single Server" mode where it was installed on the computer.
I need to generate a new key for the new server because the old one was disjointed.
When generating the new key I come across the following message stating that a key has already been generated for the licenses.
I need this key to be deleted so I can generate the new key.
First Autodesk is a company and not software.  What Autodesk software you're even referring to?  In addition can you share the actual message you're seeing?  Are you seeing a max activation limit?  Never heard of a message stating the key has already been generated...   Please clarify..
Mark Lancaster
Administrator Productivity
