@jorgeluizQ37J5
This is an English Speaking forum and when your info is translated we see this
License Server Exchange
Good morning gentlemen,
I have 2 licenses of Autodesk to be installed in NETWORK.
An activation key was generated in "Single Server" mode where it was installed on the computer.
I need to generate a new key for the new server because the old one was disjointed.
When generating the new key I come across the following message stating that a key has already been generated for the licenses.
I need this key to be deleted so I can generate the new key.
First Autodesk is a company and not software. What Autodesk software you're even referring to? In addition can you share the actual message you're seeing? Are you seeing a max activation limit? Never heard of a message stating the key has already been generated... Please clarify..
Mark Lancaster
& Autodesk Services MarketPlace Provider
