Installation & Licensing
License activation
6 REPLIES 6
bhavinbarbhaya60
367 Views, 6 Replies
License activation
I haven't received my serial number of license activation on my mail yet if anyone can check it out it would be helpful !
6 REPLIES 6
pendean
in reply to: bhavinbarbhaya60
Autodesk has not offered serial numbers for a few years now: is this an EDU or commercial license?
And for which software?
Simply start the program then login using the email address used by you to get the license.
bhavinbarbhaya60
in reply to: pendean
Oh hey there ! I actually purchased the commercial license. The problem was that I couldn't sign in 'autodesk access' app. So eventually after I went through some follow up posts from Autodesk  I finally found the solution and was able to solve that problem and I could start the app and start working.
I just happened to realize that just in case if I wasn't able to sign-in regardless the guides and other things it would be helpful if I had an alternative solution just in-case. You know if you had problems with online transactions you file a ticket or alternatively you could go directly to bank to solve it(it's an simple analogy). It's just like that ! I thought maybe if I was provided with serial number even if it were useless to me I could just keep it in hand as a secondary option.
Thanks  again for the tip though !!
Hi if you have purchased a commercial license you are entitled to Autodesk support and you can open a ticket from your Autodesk Account. As said, Serial Number licenses are not provided anymore, since 2018, therefore it's not a secondary option.
pendean
@bhavinbarbhaya60 wrote:
... it would be helpful if I had an alternative solution just in-case...
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Oh I see got it ! I didn't knew it was like that in anycase thanks for your assist and I appreciate the tip !
bhavinbarbhaya60
Got it ! Thanks for bringing that up since I am new to this things I now understand. Really appreciate the help !
Administrator Productivity
