Installation & Licensing
Issues Installing Inventor Professional 2021
22 REPLIES 22
Message 1 of 23
francesco.bacchini
2062 Views, 22 Replies
Hi everyone, I'm having several issues trying to install Inventor Professional 2021.
As or right now this is what appear to be installed on my machine:
I don't know why there are several applications that have been duplicated.
I've already tried uninstall every Autodesk product and reinstall them one by one, but nothing changed.
What should I do?
Is there a way to entirely clean Inventor 2021 (also from the Registry) and then correctly install Inventor Professional 2021?
Control Panel TabControl Panel Tab
Start Tab - Clearly no Inventor 2021Start Tab - Clearly no Inventor 2021
Labels (1)
22 REPLIES 22
Message 2 of 23
First ... stop using the Install Now method ... clearly it's not working for you.
Try the following full installer
http://trial2.autodesk.com/NetSWDLD/2021/INVPROSA/4259FA38-2218-4FF7-80E2-5464B7969683/SFX/Inventor_Pro_2021_English_Win_64bit_Dlm_001_003.sfx.exe
http://trial2.autodesk.com/NetSWDLD/2021/INVPROSA/4259FA38-2218-4FF7-80E2-5464B7969683/SFX/Inventor_Pro_2021_English_Win_64bit_Dlm_002_003.sfx.exe
http://trial2.autodesk.com/NetSWDLD/2021/INVPROSA/4259FA38-2218-4FF7-80E2-5464B7969683/SFX/Inventor_Pro_2021_English_Win_64bit_Dlm_003_003.sfx.exe
Try the foolo
Mike Davis
Message 3 of 23
Hi @francesco.bacchini,
Have you tried running the browser download installer, it tends to have fewer issues than other installers. You will know for certain if Inventor (or it thinks) is already installed by the blue ribbon that appears when it comes to selecting what components to install.
https://knowledge.autodesk.com/customer-service/download-install/download/about-download-methods/bro...
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 4 of 23
@mdavis22569 thanks for your quick reply.
I think that before trying your method I should delete every single thing related to Inventor, right? Is there a working method for that?
Message 5 of 23
Let's download all 3 of mines.  As it's downloading, delete what's in your C:\Autodesk for Install now and Inventor.
Once all 3 of mine are downloaded. Turn off the Anti-Virus / Firewall.   Make sure you have Admin rights and double click on OO1
It should ask you where to extract it ... extract it as you normally word and lets go from there.
Mike Davis
Message 6 of 23
@mdavis22569 I'll try, but I'm scared this could mess things up even more. This is what I found in my C/Autodesk folder:
I think that yesterday I accomplished to delete every single trace of Autodesk on my PC without having to hard reset it... but somehow I'm still having issues installing Inventor Professional 2021.
Should I start over once again? I could definitely delete Autodesk traces even from the registry (Regedit), but I'm scared my issues could occur again.
Message 7 of 23
Run the Microsoft Fixit Tool:
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-r...
If you have a 2nd drive, move the C:\Autodesk folder ..
This is just ALL of your installers.  So it's just taking up space.
Mike Davis
Message 8 of 23
I don't have a second drive. I'll try running the tool. Let's see what happens.
Message 9 of 23
Just trying to clean up some space.   You can clean out the C:\Autodesk of the old software that won't hurt Anything
Mike Davis
Message 10 of 23
@mdavis22569 okay, I've decided to start from scratch once again by cleaning every Autodesk product from my computer. I'm using "Everything" to perform deep files research on my local hard drive and here what's left:
There are some pictures (Keyshot stuff) an Event Log (unable to delete it, but I'd like to) and a strange folder I can't access.
Do you know how can I delete everything and then start from scratch with the installation?
P.S. I've also cleaned the registry under:
- HKEY_CURRENT_USER\Software\Autodesk
- HKEY_LOCAL_MACHINE\Software\Autodesk
and
  • HKEY_ CURRENT_USER\Software\Wow6432Node\Autodesk
  • HKEY_LOCAL_MACHINE\Software\Wow6432Node\Autodesk\Inventor\ RegistryVersion25.0
There are still some Autodesk traces in the HKEY_ROOT folder, but I'm not sure if I can touch it or not.
Message 11 of 23
leave it ....
Run the Microsoft fix it ... while my files are downloading and try my installer
Mike Davis
Message 12 of 23
@mdavis22569 leave what?
Are you referring to the ROOT folder?
I've already used your Fixit tool, but I'll try using it again.
I'm now downloading your files.
P.S. I'm under educational Licence. How can I authenticate then?
Message 13 of 23
Do you show Inventor in your Account Manager as educational?
https://manage.autodesk.com/cep
If so, you'd just use your Autodesk ID to activate it
Mike Davis
Message 14 of 23
@mdavis22569 this is what I'm seeing:
2021_02_23_HpEnvy-Francesco_14_37_26.png2021_02_23_HpEnvy-Francesco_14_37_37.png2021_02_23_HpEnvy-Francesco_14_37_45.png2021_02_23_HpEnvy-Francesco_14_37_53.png
Message 15 of 23
Perfect .. just need to use your ID to activate it ...
Mike Davis
Message 16 of 23
EDIT: Let me know what my steps should be at this point.
I'm still trying to have installed and fully functioning the following:
Autocad 2021
alias 2021
inventor professional 2021
fusion
Message 17 of 23
@mdavis22569
okay, so do you still recommend using the files you gave me instead of autodesk installer?
Message 18 of 23
Mine are the full offline installer. You've used ( going by images) the Install Now, which can have a lot of issues for some.
Mike Davis
Message 19 of 23
@mdavis22569 I'll try using your installers in a couple of hours. I'll let you know if I need further help. Thanks for your support!
Message 20 of 23
@mdavis22569 I'm trying to use the Fixit Software. What should I press here?
Administrator Productivity
