Installation & Licensing
Inventor 2021 won't open
24 REPLIES 24
Message 1 of 25
1742 Views, 24 Replies
I was told by customer service to come here.
I have the student version of Inventor 2021 and tried to open it for the first time but it didn't.
It loaded for like two seconds and then nothing happend. I tried to reinstall it with the same outcome.
Customer service thinks my problem has something to do with product functionality.
Does anyone know whats wrong and can help?
24 REPLIES 24
Message 2 of 25
mdavis22569
Did it ever work?
Also, have you tried turning off the firewall / anti-virus and starting it ?
http://trial2.autodesk.com/NetSWDLD/2021/INVPROSA/4259FA38-2218-4FF7-80E2-5464B7969683/SFX/Inventor_...
Download all 3 and try running the installer again.
Mike Davis
Message 3 of 25
JDMather
Do you have these three files?  (I'll wager no.)
Can you ask your instructor to join this discussion?
Message 4 of 25
I don't know if it ever worked on my pc since I had never tried to open it before.
All updates are installed.
I hope that this os the right info about the
Videocard: Treiberversion 20.20.33.02-201105a-360732E-RadeonSoftwareAdrenalin2020
and driver: Vulkan™ Driver Version 2.0.158
I now also tried to open it without anti-virus but nothing has changed
Message 5 of 25
mcgyvr
@Anonymous  Try opening the "Services" app on your computer and find "Autodesk Desktop Licensing Service" and make sure its started and running then try to open Inventor again.
Message 6 of 25
in reply to: mdavis22569
I also tried to download the 3 files but when opening/extracting it not only foze my browser but also said that a file was missing (all 3 times). Inventor still won't open.
Message 7 of 25
in reply to: JDMather
I don't think I have them and my teacher is curently away to supervise an exam.
Message 8 of 25
in reply to: mcgyvr
It already run, so it still doesn't open.
Message 9 of 25
mdavis22569
So let's go back a step.
Is the software currently installed?
Mike Davis
Message 10 of 25
Yes, it is.
Message 11 of 25
mdavis22569
So then forget about all of the extracting and downloading ....
Do you have the Autodesk Desktop app installed?
If so, is it working?   Do you see any updates needing to be installed?  If so, please install them.
Mike Davis
Message 12 of 25
I have it installed and as far as I know it does work and no updates need to be installed.
Message 13 of 25
mdavis22569
So when you go to open Inventor .. how far does it get?
Also, can you try right clicking on the Inventor icon and clicking Run As Admin and see if it starts?
Mike Davis
Message 14 of 25
I double click and for maybe one or two seconds the little loading circle shows up and then nothing.
As for running it as an admin, a pop.up shows up with asks if i'm ok with letting this program make changes on my pc (kinda translated since it's in german) I click yes and the same as mentioned in the last sentence happens.
Message 15 of 25
mdavis22569
So it sounds like you might not have the right permissions / admin rights to run this program on your PC
Mike Davis
Message 16 of 25
But what can I do? I'm the only one using my pc.
Message 17 of 25
mdavis22569
Lower your UAC ( User Access Control )
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-t...
and
How to set up antivirus (AV) exclusions to improve stability and performance of Autodesk software
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Are-there-antivirus-excl...
Which URLs/Protocols need to be white listed for Autodesk Subscription Licenses
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/What-U...
Mike Davis
Message 18 of 25
I did all this (hopefully right) and now trying to open it normal and as admin doesn't differ in any way with the same non functioning outcome.
Message 19 of 25
mdavis22569
Does it now open and let you work in a file?
Mike Davis
Message 20 of 25
No, it still doesn't open.
Administrator Productivity
