I am installing the AutoCAD 2021 in my PC. There is a error occur initially.
Solved by leowarren34. Go to Solution.
Hi, @sufyangmssg,
That error usually means there is a problem with your temp folder - try clearing it out as much as you can (some system files in there may be in use and thus be unable to be deleted).
Next, try running the installer admin,
Failing that follow the article here which contains the steps to create a new temp folder: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Instal...
Hi Sir,
I am very thankful to you to solve my issue with great of your experience. But sir, I have a probem in point 11, how to restore default setting.
Hi @sufyangmssg,
Did you create a text file with the normal values?
If not then you need to find the path to your regular temp folder which is usually located under C Drive -> Users -> (Your User Name) -> Appdata -> Local -> Temp
Then repeat the steps in reverse.
Did you intend to upload anything?
What is the specific problem?
I am unable to solve this issue because when I am going according to provide your instruction but I am not seeing app data folder. Please if you send me a screen shoot of how to set default setting. I am very thankful to you.
With bet regards.
