i got this message when i tried to install 3Ds Max from my autodesk account and when i pressed OK, the installation has been canceled.
Is there any possibility to solve this problem?
thank you in advance
Solved by natasha.l. Go to Solution.
Hello @Anonymous,
You can download your software via the Autodesk Virtual Agent it's a more effective method.
You tried installing before so please run through these steps:
Please "Accept As Solution" to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
