Installation & Licensing
Installation error 1631 Autocad LT 2021 upgrade
7 REPLIES 7
Message 1 of 8
ronholtz01
4261 Views, 7 Replies
I have a subscription to Autocad LT 2020 on my Windows 10 AMD based workstation.  Today I received an email from Autodesk saying that I was eligible to upgrade to version 2021. I downloaded the installation file and extracted it to the correct folder.  The installation gets to item 8 of 11 and then gives me an error message 1631 saying that my Windows Installer was not running.  I checked my services folder and discovered that it was running.  I tried several more times to download the files and install to no avail.  I was told by an Autodesk tech on chat to download using my browser.  Still nothing. I went on chat again and the second tech told me that I should wait a couple of days and try it again because everything has not synced up yet since I just received the email today. Does anyone have any ideas for me to try next?  Thanks in advance.
7 REPLIES 7
Message 2 of 8
DarrenP
in reply to: ronholtz01
read this: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Pb-d-i...
DarrenP
Message 3 of 8
ronholtz01
in reply to: DarrenP
I l ended up having to do a reinstall of Windows 10 and a fresh install of Autocad LT 2021.
Message 4 of 8
RobtRoma
I have this issue as well.  I just tried to apply this solution.  There are no "Null" values in that Registry Location.  The only Autodesk entry I can find is named ADSK_CLM_WPAD_PROXY_CHECK and its value is set to FALSE.  There is an entry called (Default) that says (value not set) but that is a system value that is in every registry location.   Are there any other possible solutions?
Message 5 of 8
I am getting the same error with the trial version, doesn't encourage me to pay for the actual product. I deleted all Autodesk software off my computer and tried again. Still not working. This is infuriating! Total loss of $$$ messing with this just to open one file.
Message 6 of 8
I don't even have the slightest idea how to reinstall Windows, so that sucks for me.
Message 7 of 8
Contact Microsoft support via chat, they usually reply within 5 minutes and can guide you through the process.
Message 8 of 8
Or contact Autodesk support to help you with your installation issue.
Administrator Productivity
