Installation & Licensing
Install Failed Revit 2018.1.1 Hot Fix
4 REPLIES 4
ahmedallam340
670 Views, 4 Replies
While updating revit 2018 to revit 2018.1.1 it gives install failed error
kindy find my attached  install errors log
4 REPLIES 4
Otto
in reply to: ahmedallam340
Hello ahmedallam340 and welcome to the Autodesk community!
It looks like you are having Revit installation issues. Community members with similar questions found the following article(s) useful:
For issues with Revit Server, please see the System Requirements for Revit Server.
If you are installing on Windows 10, please check that your product is compatible.
Software & Downloads
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Performing a Clean Uninstall
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Same problem please check my install log try to setup on windows 10
@ahmedallam340
There's other installation log files associated to this install.   Zip them up and attach here.
In addition how are you using to install this?  Through the Autodesk Desktop App?  If so don't..  Download and install through your Autodesk Account.
Mark Lancaster
Yes downloaded via autodesk desktop manager, and same problem with revit 2017.2.2 update
Administrator Productivity
