Installation & Licensing
instalation complete, some products failed to install
3 REPLIES 3
359 Views, 3 Replies
Hi,  I am trying to install autodesk to my new computer and keep getting the above error.  I see from others that I should delete the Microsoft visual C  but I don't know which ones to delete.
I looked for "perquisite" in the log, and nothing.  I did find an error - Failed Download Failed, Installation aborted, Result=1603" bit again, I don't know from that what to cancel.
please help, this is getting old fast.
3 REPLIES 3
Otto
Hello brett.staats and welcome to the Autodesk community!
It looks like you're seeing the "Some Products Failed to Install" error. This error can be caused if prerequisites have already been installed on the target machine. Incompatible versions, or even the same version, can cause this problem. The following article(s) should help you resolve the problem:
Error: "Install complete. Some Products Failed to Install"
After uninstalling the necessary files, please fully shut down your computer and reboot it for the changes to take effect.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Darin.Green
The issue is due to using the Web Installer. Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
Thank you!  Thank you! Nit worked!  Thank you!
Administrator Productivity
