Installation & Licensing
302 Views, 3 Replies
Download
Started download of Revit 2017 trial and power knocked out in neighborhood at about 15% into download. When power is restored should I start over?
3 REPLIES 3
Darin.Green
Download the software from the Autodesk Virtual Agent
Once there, use the Download Links option to navigate to the application you need to download.
NOTE: If there are multiple parts for the download, you'll need to click each part to download them, once they are downloaded double-click Part1 (which will automatically extract the remaining parts) to begin the installation.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
Not working. Did the virtual site and re-install. Said all is installed but won't open - get the hourglass. Should I uninstall everything and start over?
Mick Wilkinson
Darin.Green
No, when you double-click the shortcut, do you get the splash screen?
Update your graphics card driver from the vendors site and try launching the application again.
Administrator Productivity
