Problem:
I'm constantly being prompted to install update "Inventor CAM 2022.3.1 Hot Fix" even though Inventor CAM 2022 is not installed on the computer.
History:
Previously I had Inventor Professional 2022 and Inventor CAM Ultimate 2022. I performed clean uninstalls of both products by following Autodesk articles provided by Autodesk Support. I verified the computer directory structure was free of anything Autodesk. I then rebooted and ran NirSoft RegScanner v2.65. Using insensitive search with keywords (autodesk, autocad, inventor, cam), RegScanner identified a dirty registry with several thousand leftover Autodesk registry keys. I deleted them, rebooted, and ran RegScanner again to verify the registry was clean of anything Autodesk.
With a completely Autodesk free computer I perform Autodesk Support approved clean installs of Inventor Professional 2023 and Inventor CAM Ultimate 2023. Updates to those products went normally.
A day later and the "CAM 2022.3.1 Hot Fix" appears. If I click 'Update' it obviously fails and correctly reports the required product is not installed. However, the update notification will not go away.
How do I make this unnecessary update notification go away?
Maybe it's simply a database sync problem on Autodesk's side?
Update: 05/10/22
Someone in the Facebook group Autodesk Inventor Community stated,
"It's not just restricted to Inventor CAM. I also had this happen with Autocad as well. I'm currently just ignoring the notification."
