Hello everyone,
I had the 30 day trial that ended a few days ago. I am a student with a student license for programs like Revit and Autocad and those work just fine. For some reason Formit doesn't see that I have a student license and won't let me use te program as a student. When I start Formit it just says that my trial is over. I tried relogging and redownloading but both didn't work. When I search on student products on the autodesk site Formit also has a student version. Are there any solutions to fix this? Thanks in advance!
Solved by DarrenP. Go to Solution.
you would have to Contact EDU support here: https://www.autodesk.com/education/support/edu-contact-us-form
this looks to be a backend issue only they can fix
DarrenP
I have this same problem, I've never been able to access formit pro with my student account which is really a shame because it seems like a pretty cool software.
for form it its not showing installation option for student .
pls can you tell how to install.
Formit is end of life, so you might want to use something else?
