I recently purchased the MacBook Pro (2016) touch with Radeon 450 graphics card. When I first install Flow design it asks me to allow unidentified developers through, which I can do and so Flow design installs. However when I try to open flow design I get a Fatal Exception message and the programme has to quit. Is there anything that can be done to solve this issue? Attached are two photos: the first one I can bypass by changing system preferences. How do I solve the second error?
Thank you
Michael Burnford
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Am I missing something here... Autodesk Flow Design is not a MAC OS supported product.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
I'm not a Flow Design or MAC OS user. I will not have the answer for you and most likely no one here will either.. Its not a common Autodesk product that gets supported here but I did find an article indicating MAC OS was supported now. But I also found a posting that its not supported under the 10.12 version OS. Check with the actual users and see if they know..
Mark Lancaster
