Software publishers must register the ports they use with some central
authority, and Macrovision has done that with FLEXlm. For the long term,
you should find out what was using FLEXlm's port, and correct it. You may
have only deferred the problem for a short time (until you install something
else that has registered port 29005). (This is assuming you didn't
originally change FLEXlm's port; I don't remember what its registered port
is).
--Cy--
"Ken C" wrote in message
news:F5A11467D8A8CB89CC01E0CC66603B0E@in.WebX.maYIadrTaRb...
> Thanks for the response, it turns oout it was a port problem, when I
changed
> the port number from 27005 to 29005 it started working.
> -k
> "jerry milana" wrote in message
> news:27767217A1399D735788BB6C597ED8E9@in.WebX.maYIadrTaRb...
> > Ken,
> > You are correct in that you have a communication problem between your
> > servers. Security software will often cause this behavior. Also
remember
> > that all three servers must reside in the same network segment and
should
> be
> > as physically close to each other as possible. If you continue to have
> the
> > problem, consider distributed servers as that configuration is more
> > forgiving from a network aspect.
> > Jerry Milana,
> > Autodesk Professional Services
> > news:CA3F783574757A5D56F9E8B3639075F5@in.WebX.maYIadrTaRb...
> > > I'm haviong trouble getting redundant servers setup, one issue may be
> the
> > > fact that the server status shows 2 masters.
> > > Flexible License Manager status on Mon 10/27/2003 14:35
> > > [Detecting lmgrd processes...]
> > > License server status: 27005@server1,27005@server4,27005@server5
> > > License file(s) on server1: C:\Program Files\Autodesk Network
> License
> > > Manager\License\ADT.lic:
> > > server1: license server UP (MASTER) v8.3
> > > server4: license server UP v8.3
> > > server5: license server UP (MASTER) v8.3
> > > Vendor daemon status (on server5):
> > > My understanding is the first server listed on the lic file is the
> master
> > > and if it is not available then the second server is the master, my
> setup
> > > shows 1 and 3 as the masters??
> > > Also when I check the debug log it looks like the different servers
> can't
> > > talk to each other even though they are all using the same port and
are
> > set
> > > up the same
> > > 14:34:28 (lmgrd) Connection to server1 TIMED OUT
> > > 14:34:28 (lmgrd) Connection to server4 TIMED OUT
> > > 14:36:28 (lmgrd) license daemon: lost all connections
> > > 14:36:28 (lmgrd) This is an internal error. lmgrd will now
> > > 14:36:28 (lmgrd) attempt to re-establish contact with other daemons.
> > > 14:36:58 (lmgrd) Connection to server1 TIMED OUT
> > > 14:36:58 (lmgrd) Connection to server4 TIMED OUT
> > > 14:36:59 (lmgrd) license daemon: lost all connections
> > > 14:36:59 (lmgrd) This is an internal error. lmgrd will now
> > > 14:36:59 (lmgrd) attempt to re-establish contact with other daemons.
> > > 14:37:29 (lmgrd) Connection to server1 TIMED OUT
> > > 14:37:29 (lmgrd) Connection to server4 TIMED OUT
> > > By the way it doesn't want to work and I'm guessing that this might be
> the
> > > issue.
> > > thanks
> > > -k
