Dear Team,
We are using ACAD 2018 network license, while working on the same in between we get a popup message saying
The product license is no longer available. Please save your work and shutdown
attached screeenshot below, can some someone please guide.
Solved by mdavis22569. Go to Solution.
Solved by pendean. Go to Solution.
https://knowledge.autodesk.com/support/3ds-max/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-...
On this AKN page, there is a troubleshooting form. Have you seen this
https://autode.sk/32xqOyu
Most of all:
We want to make sure you have the Licensing update installed:
https://knowledge.autodesk.com/search-result/ca...
Direct link to the update:
https://knowledge.autodesk.com/search-result/caas/downloads/content/march-2020-autodesk-licensing-se...
AdskLicensingInstaller-win-12.1.0.7121 installer file.
https://knowledge.autodesk.com/search-result/caas/downloads/content/autodesk-licensing-service-downl...
We also want this update:
Autodesk Single Sign On Component 2020.1:
https://up.autodesk.com/2020/ADSSO/A97BF60C-1A84-42CF-865F-FADC3E0E8DBA/AdSSO.msihttps://up.autodesk...
We also want to make sure all of the Autodesk updates showing in the Autodesk Desktop app are installed .. for both AutoCAD and Autodesk products (licensing)
Mike
