Installation & Licensing
Error 20 the licensing error
12 REPLIES 12
Message 1 of 13
3690 Views, 12 Replies
Hello!
I've been trying the last 3 days to get maya 2015 and/or 2016 to work on my macbook air, this error comes up:
License was not obtained
Tried Maya 2015 (657G1 2015.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
And now I have been looking through every piece of information there is to find, and nothing yet has helped me.
Anyone help?
Edit: also I have tried it on the 10.8 os before and this happened to, I now have yoshimite (10.10.5)
12 REPLIES 12
Message 2 of 13
Otto
Hello kebbabena and welcome to the Autodesk community!
It looks like you are seeing License was not obtained: error 20. The following articles should help you resolve the problem:
How to force re-activation of a product
Did that work? If so, please accept this solution so that others can benefit from this information. If not, please reply with additional details so that other community members can assist.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 13
in reply to: Otto
Not one of those links works and I don't even know what smoke is or what it has to do with "MAYA" and I do not have an application called smoke on my mac either. And what additional details do you need? I don't really have anything left to say other than: My maya doesn't work because of error 20
Message 4 of 13
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried installing the latest service pack for Maya 2015 or the service pack for Maya 2016. Also try the workarounds suggested in the pervious posts:
The first workaround to this issue is to set the language of your Mac OS X system to English.
Perform the following tasks to set the language to English:
  1. Open System Preferences.
  2. Click Language & Text.
  3. Drag English to the top of the language list.
  4. Restart your Mac.
If the error still persists, try the following procedure:
  1. Open the Terminal app from the Applications > Utilities folder.
  2. Type the following command:
    sudo mv /Library/Preferences/FLEXnet\ Publisher/FLEXnet/adskflex_* /var/tmp
  3. Enter your password when prompted.
  4. Restart Program.
  5. The application will go through the activation process again and should recognize the existing license and use it.
  6. If you are still getting error 20, reopen the Terminal and type:
    sudo mv /Library/Application\ Support/Autodesk/ADLM /Library/Application\ Support/Autodesk/ADLM.old
  7. Uninstall and reinstall.
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Message 5 of 13
in reply to: matthew.d
exactly the same solution as in the first link... which still doesn't work because i do not have smoke on my computer.
Message 6 of 13
in reply to: Otto
anyone help?
Message 7 of 13
matthew.d
Hi @Anonymous,
Those directions are not Smoke specific. Did you try the service packs that were linked above?
Matt DiMichele
Message 8 of 13
didn't work, same error
Message 9 of 13
in reply to: Otto
Bump
Message 10 of 13
do you have any other solutions?
Message 11 of 13
gg no reply in over 2 weeks
Message 12 of 13
PROBLEMAS CUANDO NO ABREN PROGRAMAS DE AUTODESK
SOLUCION 1 :Cuando los programas de Autodesk no abren o cuando abren y se cierran en segundos ,Error falló 20 Licencia
Equipo-Vista-Elementos Ocultos- activar -(archivos ocultos) , luego
Equipo-Disco local C:/ProgramData/FLEXnet
Eliminar Archivos dentro de esta carpeta
SOLUCION 2 : Cuando los programas de Autodesk no abren o cuando abren y se cierran en segundos,Error falló 20 Licencia
Haga clic en Inicio y escriba "services.msc"
En servicios busque el servicio de licencias Flexnet y haga doble clic en él
Cambie el tipo de inicio para este servicio de manual a automático , o
Click derecho , propiedades, tipo de inicio , cambiar a automatico, aplicar , aceptar
Reiniciar equipo
Message 13 of 13
sporksalot1
I'm having this exact same problem.
I've tried all the suggested solutions here and the problem still exists.
the help for unistalling maya says to use the adlmreg command to clean up previous installations.  however when i try to run admlreg from the terminal i get a "command not found" error.
When i try this:
it changes from error 20 to error 41.
thanks
eric
Administrator Productivity
