Hello!
I've been trying the last 3 days to get maya 2015 and/or 2016 to work on my macbook air, this error comes up:
License was not obtained
Tried Maya 2015 (657G1 2015.0.0.F), error 20
License method:
environment variable MAYA_LICENSE_METHOD='standalone'
Product choice:
environment variable MAYA_LICENSE='unlimited'
License file override:
environment variable MAYA_ALT_EN is not set
And now I have been looking through every piece of information there is to find, and nothing yet has helped me.
Anyone help?
Edit: also I have tried it on the 10.8 os before and this happened to, I now have yoshimite (10.10.5)
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried installing the latest service pack for Maya 2015 or the service pack for Maya 2016. Also try the workarounds suggested in the pervious posts:
The first workaround to this issue is to set the language of your Mac OS X system to English.
Perform the following tasks to set the language to English:
If the error still persists, try the following procedure:
Hi @Anonymous,
Those directions are not Smoke specific. Did you try the service packs that were linked above?
PROBLEMAS CUANDO NO ABREN PROGRAMAS DE AUTODESK
SOLUCION 1 :Cuando los programas de Autodesk no abren o cuando abren y se cierran en segundos ,Error falló 20 Licencia
Equipo-Vista-Elementos Ocultos- activar -(archivos ocultos) , luego
Equipo-Disco local C:/ProgramData/FLEXnet
Eliminar Archivos dentro de esta carpeta
SOLUCION 2 : Cuando los programas de Autodesk no abren o cuando abren y se cierran en segundos,Error falló 20 Licencia
Haga clic en Inicio y escriba "services.msc"
En servicios busque el servicio de licencias Flexnet y haga doble clic en él
Cambie el tipo de inicio para este servicio de manual a automático , o
Click derecho , propiedades, tipo de inicio , cambiar a automatico, aplicar , aceptar
Reiniciar equipo
I'm having this exact same problem.
I've tried all the suggested solutions here and the problem still exists.
the help for unistalling maya says to use the adlmreg command to clean up previous installations. however when i try to run admlreg from the terminal i get a "command not found" error.
When i try this:
sudo mv /Library/Application\ Support/Autodesk/ADLM /Library/Application\ Support/Autodesk/ADLM.old
it changes from error 20 to error 41.
thanks
eric
