Error 1714
Error 1714
Error 1714
Hey,
I've had Sketchbook installed for a little while now, but when going to update, it does not allow it. It come up with Error 1714, I believe. It says it cannot find the older version to rewrite. I tried to uninstall the entire program and reinstall, with no luck. Any help would be great.
-Amanda
Otto
Hello freakspfx and welcome to the Autodesk community!
It looks like you are seeing a Windows Installer Error Message. The following article(s) should help you resolve the problem:
Windows Installer Error Messages
Errors during AutoCAD software installation
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
RDAOU
Hello @Anonymous
Can you please state which program/application version is it not able to locate and rewrite/remove? One of the reasons to cause this might be an earlier unlicensed/hacked copy of a prerequisite application/software or the application you are trying to install now (Sketchbook)
You can try  follow the steps below to resolve this issue.
  1. Remove any traces of the failed installation by uninstalling (add/remove programs) from Control Panel
  2. Run Microsoft Fix it utility to repair corrupted registry keys that prevents programs from being completely uninstalled or blocking new installations and updates.
  3. Run Disk Cleanup to clear out your temp files and installation files
  4. Reboot your computer
  5. Disable any antivirus and firewalls
  6. Ensure you have admin access
  7. Run the installation again
If the above is helpful and it resolves the installation issue, please mark this reply Accept as Solution
I was actually able to fix it and reinstall with the newest version. I had to install Microsoft Fix It, which forced a complete uninstall of any traces of the program, which the usual Program uninstall through windows did not do. Then when I re-installed, I had no issues.
