Tsplines activation error 110
I have installed Tsplines for rhino 4.0 in windows 7 running rhino 64 bit with the latest update. When I attempt to use a tsplines function I am prompted to activate my copy, when i select activate I get a licensing error window with the error code 110.
I have tried re installing tsplines several times with no luck.
Otto
Hello osoliman and welcome to the Autodesk community!
It looks like you're getting Error 110 during activation. This error typically occurs when something in the licensing folder is corrupt.
The following instructions should help you resolve the problem:
For Mac, please uninstall your current version of Maya and install this Service Pack.
For Windows, please uninstall ALL Autodesk software and then delete the folder containing the licensing components and then re-install. Here are the steps to do this:
  1. Uninstall Autodesk software
  2. Delete C:\ProgramData\Autodesk\Adlm and all contents
  3. Delete the ADSKFLEX files in C:\ProgramData\Flexlm
  4. Re-install autodesk software.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
