Installation & Licensing
813 Views, 4 Replies
Error 1619
Non riesco a installare AutoCAD 2017 perché mi dà l'errore 1619. In allegato il file di errore
Tags (1)
4 REPLIES 4
Otto
Hello federico.scruci and welcome to the Autodesk community!
It looks like you are seeing Error 1619 while trying to install a program. The following article(s) should help you resolve the problem:
Downloading Previous Versions of Autodesk Software Using the Virtual Agent (Please be sure to disable your firewall and anti-virus before downloading)
Autodesk program installation fails
BIM 360 Add-in install error: "A newer version of this software is already installed"
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Mark.Lancaster
@Anonymous
Welcome to the community..
Your installation is simply failing due to the method (web installer) you're using.  This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it.  Posting info: Sometimes installation log files contain personal information such as your serial #.  Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
could anyone give a solution for this error!!
2017/10/8:23:19:37 fahad MEO === Setup started on MEO by fahad ===
2017/10/8:23:19:37 fahad MEO Path_Length: 155
2017/10/8:23:19:37 fahad MEO Current Directory C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm
2017/10/8:23:19:37 fahad MEO Launch
2017/10/8:23:19:37 fahad MEO CommandLine
2017/10/8:23:19:37 fahad MEO Current Directory C:\Users\fahad\AppData\Local\Temp\_AIC64.tmp
2017/10/8:23:19:54 fahad MEO === Setup ended ===
2017/10/8:23:19:39 fahad MEO === Setup started on MEO by fahad ===
2017/10/8:23:19:39 fahad MEO Path_Length: 155
2017/10/8:23:19:39 fahad MEO Current Directory C:\Users\fahad\AppData\Local\Temp\_AIC64.tmp
2017/10/8:23:19:39 fahad MEO Launch
2017/10/8:23:19:42 fahad MEO Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\fahad\AppData\Local\Temp\_AIC64.tmp\Setup\RevitSetup.dll
2017/10/8:23:19:42 fahad MEO Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/10/8:23:19:46 fahad MEO Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\fahad\AppData\Local\Temp\_AIC64.tmp\Setup\RevitSetup.dll
2017/10/8:23:19:46 fahad MEO Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® MEP 2016. URLTitle= URLLink=
2017/10/8:23:19:55 fahad MEO PageOpen LaunchDialog
2017/10/8:23:21:14 fahad MEO PageOpen LicenseDialog
2017/10/8:23:22:11 fahad MEO PageOpen ProductInfoDialog
2017/10/8:23:24:13 fahad MEO PageOpen ProductSelectionDialog2
2017/10/8:23:24:16 fahad MEO PageOpen FullProgressDialog
2017/10/8:23:24:17 fahad MEO Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\fahad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/10/8:23:24:45 fahad MEO Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2017/10/8:23:24:45 fahad MEO Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/10/8:23:24:53 fahad MEO Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/10/8:23:24:53 fahad MEO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\fahad\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/10/8:23:25:11 fahad MEO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2017/10/8:23:25:11 fahad MEO Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\fahad\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/10/8:23:25:34 fahad MEO Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/10/8:23:25:35 fahad MEO Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2017/10/8:23:25:35 fahad MEO Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Tags (2)
Mark.Lancaster
@Anonymous
Your installation may be failing due to the information in this article.  Let us know if that resolved the issue or not.
Mark Lancaster
Administrator Productivity
