Installation & Licensing
Error 1603 during installation
6 REPLIES 6
721 Views, 6 Replies
Hello, I hope that I've chosen the right place to ask for help. Namely I've been recently trying to install AutoCAD Architecture 2019 app, yet I keep having problems with installation. I've already tried all of the solutions posted to the official Autodesk site, I also tried to force remove and uninstall all autocad related programs and their leftovers, I tried installing it with all anti virus software turned off. Every time I try to install the app, it starts to install, but after few minutes it suddenly stops and there appears message that it was unable to install the app.
I'd appreciate any king of help,
Thanks in advance!
Thanks in advance!
6 REPLIES 6
mdavis22569
mdavis22569
How are you downloading it for installation?
Please click on the link below to start.
Part 2
Turn off the UAC (Autodesk User Access Control )
Turn off the Firewall / Anti-Virus
Clean out the %temp% folder
Mike Davis
Part 2
Mike Davis
Mark.Lancaster
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Adding to @mdavis22569 reply..
Without your installation log file we can only speculate what the issue is at this point.  So attach your installation file here so we can review it.
Posting info: Sometimes the installation log file contains the serial # that was assigned to you.  Open your log file using Windows Notepad and perform a search on "/SN".  Depending on the number of installation attempts, your serial # may be located throughout the log file.  If present, remove or "X" out your serial # prior to posting.
Mark Lancaster
@Anonymous
Mark Lancaster
in reply to: Mark.Lancaster
So after I've tried the solution of  @mdavis22569, which did not succeed, I've saved log files. For some reason after I've downloaded both files I had to run 2 installers, is it the way it's supposed to be? I mean, i thought that there's gonna be one installer for everything that was extracted.
Mark.Lancaster
Mark.Lancaster
@Anonymous
No need to run 2 installers..  The method @mdavis22569 gave you will automatically extract both parts that you downloaded..  At this point you most likely have a messed up installation..
However your  faced with this problem..  A 1603 failure on a core Autodesk product..  Not good.  Smiley Sad
See @TravisNave and my information in this posting.   Some users have had success in reinstalling Windows but that's not really a viable solution.
At this point, I would recommend that you perform a clean uninstall per these instructions.   NOTE: The information within the article is solely based on you performing a clean uninstall of all "core" Autodesk products on your machine.  In certain situations, you will most likely not be removing all of your Autodesk products to resolve a given issue.  If that's the case, you'll need to adjust those settings and locations within the article to make sure you are not impacting those other Autodesk products you plan on leaving on your machine.
Followed by the suggestions that are in that article I referenced above.
Mark Lancaster
@Anonymous
Mark Lancaster
Okay, I'm going to study your post that you've sent and try to solve that issue. I was kind of aware that one of the solution might be reinstalling windows, which I'd rather avoid right now. I'm going to update my case as soon as i finish. Thanks for help!
So I've tried everything from the posts you've sent, and it did not work.(I changed the Temp folders, turned of UAC, turned off all anti virus software, clean uninstalled all autodesk products)
Administrator Productivity
