I'm trying to run a fresh install, (Win7 x64) network version and continue to get the message that .net 4.0 is not installed.
I checked windows updates and it's listed, along with installing from MS site .net 4.0 to which it gives me the option ot repair or remove, I repair and that finishes.
I've rebooted the pc and started to install autocad 2012 again, with the same message and end result of failed install and this failure in the log
DirectX® Runtime Failed Failure is ignored, Result=1619
Any help is appreciated.
Solved by Darin.Green. Go to Solution.
Hi there,
thanks for the reply I wasn't able to install Autocad or Autodesk Architecture separately
I deleted all autodesk entries in the registry but they kept coming back with every reboot (autodesk digital signatures folder)
uninstalled all software before purging the registry and the only autodesk file I could find was autodesk.rex in the windows 32 system files
I tried to delete this file but it said it was open in another program.
I tried rebooting into safe mode and deleting it but still no luck it was still in use and same thing when I tried to shred the file
I have reinstalled windows which is not much of a hardship on windows 10 although it did take a while to create a backup image of my system
All software installed and working perfectly now
thank you for your help and hopefully this info may help someone else
Bonjour,
J'ai un problème qui persiste lors de l'installation d'autocad. J'ai essayé avec différentes versions mais toujours le même message persiste au bout d'un tier de l'installation du logiciel. Dans le dialogue des détails d'installation le même message de fin : DESKTOP-RG65U4K Rollback DirectX Runtime Failed Failure is ignored, Result=1619 . Si quelqu'un à la solution au problème, et s'il pourrait le partager avec nous ici. Merci d'avance et bonne journée.
@Anonymous
Welcome to the community...
A single line from your installation log file is not helpful. Most likely the failure occurred higher in the log file. We would need to see the entire log so we can pinpoint your issue. However I will assume its failing based on the method you're using so
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
hello
i'm a student and i'm trying to download the program but i've this problem
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/17:22:02:54 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI3EFB.tmp
2017/3/17:22:17:20 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/17:22:02:56 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/17:22:02:56 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/17:22:02:56 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI3EFB.tmp
2017/3/17:22:02:56 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/17:22:03:57 Maria Elena LAPTOP-GELMANU4 Download Play SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/17:22:03:58 Maria Elena LAPTOP-GELMANU4 Download Complete SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/17:22:03:58 Maria Elena LAPTOP-GELMANU4 Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/17:22:17:18 Maria Elena LAPTOP-GELMANU4 Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/17:22:17:18 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AI3EFB.tmp\Setup\AcSetup.dll
2017/3/17:22:17:18 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/17:22:17:21 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/17:22:23:32 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/17:22:23:32 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/17:22:23:32 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/17:22:24:11 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/17:22:24:12 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/17:22:24:12 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/17:22:24:13 Maria Elena LAPTOP-GELMANU4 Download Play VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:24:22 Maria Elena LAPTOP-GELMANU4 Download Complete VCREDIST2008SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:24:22 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/3/17:22:25:03 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/3/17:22:25:04 Maria Elena LAPTOP-GELMANU4 Download Play VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:25:13 Maria Elena LAPTOP-GELMANU4 Download Complete VCREDIST2010SP1X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:25:13 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart /l C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2010.log
2017/3/17:22:25:21 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/3/17:22:25:22 Maria Elena LAPTOP-GELMANU4 Download Play VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:25:33 Maria Elena LAPTOP-GELMANU4 Download Complete VCREDIST2010SP1X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:25:33 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart /l C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2010.log
2017/3/17:22:25:42 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/3/17:22:25:42 Maria Elena LAPTOP-GELMANU4 Download Play UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/17:22:25:53 Maria Elena LAPTOP-GELMANU4 Download Complete UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/17:22:25:53 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/17:22:25:53 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/17:22:25:54 Maria Elena LAPTOP-GELMANU4 Download Play VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:26:16 Maria Elena LAPTOP-GELMANU4 Download Complete VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:26:16 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/17:22:26:17 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/17:22:26:18 Maria Elena LAPTOP-GELMANU4 Download Play VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:27:52 Maria Elena LAPTOP-GELMANU4 Download Complete VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/17:22:27:52 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/17:22:27:52 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/17:22:27:53 Maria Elena LAPTOP-GELMANU4 Download Play DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/17:22:28:45 Maria Elena LAPTOP-GELMANU4 Download Complete DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/17:22:28:45 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/17:22:29:39 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/17:22:29:40 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/17:22:50:14 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/17:22:50:14 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/17:22:50:15 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/17:22:50:15 Maria Elena LAPTOP-GELMANU4 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/3/17:22:50:15 Maria Elena LAPTOP-GELMANU4 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/3/17:22:50:16 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/17:23:51:28 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/17:23:56:41 Maria Elena LAPTOP-GELMANU4 Setup Windows update reboot is pending
2017/3/17:23:56:44 Maria Elena LAPTOP-GELMANU4 Setup Autodesk® AutoCAD® 2017 Will restart automatically.
2017/3/17:23:56:44 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:00:14:51 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI7008.tmp
2017/3/18:00:15:24 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:14:59 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:14:59 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:14:59 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI7008.tmp
2017/3/18:00:14:59 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:15:00 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:00:15:00 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:00:15:00 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AI7008.tmp\Setup\AcSetup.dll
2017/3/18:00:15:00 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:00:15:03 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:00:15:28 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:00:15:28 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:00:15:28 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:00:15:53 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:00:15:54 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:15:55 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:00:15:57 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:00:15:57 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:15:57 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:00:15:58 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:00:15:58 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:00:15:58 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:00:16:18 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:00:16:19 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:00:25:29 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:00:25:29 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/18:00:25:30 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/18:00:25:33 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:00:28:03 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:00:30:47 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIB1B.tmp
2017/3/18:00:30:54 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:30:49 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:30:49 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:30:49 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIB1B.tmp
2017/3/18:00:30:49 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:30:50 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:00:30:50 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:00:30:50 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AIB1B.tmp\Setup\AcSetup.dll
2017/3/18:00:30:50 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:00:30:51 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:00:30:59 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:00:30:59 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:00:31:12 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:00:31:13 Maria Elena LAPTOP-GELMANU4 Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=it-it SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={B167238D-E6FA-432D-968A-BBB82C9BB71E} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:00:31:15 Maria Elena LAPTOP-GELMANU4 Install Network License Manager Succeeded
2017/3/18:00:31:16 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:31:17 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:00:31:18 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:00:31:18 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:31:18 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:00:31:19 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:00:31:19 Maria Elena LAPTOP-GELMANU4 Download Play CADM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CADM_x64_...
2017/3/18:00:31:28 Maria Elena LAPTOP-GELMANU4 Download Complete CADM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CADM_x64_...
2017/3/18:00:31:28 Maria Elena LAPTOP-GELMANU4 Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=it-it SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),;;;;" PACKAGEUPI={B167238D-E6FA-432D-968A-BBB82C9BB71E} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:00:31:31 Maria Elena LAPTOP-GELMANU4 Install Autodesk CAD Manager Tools Succeeded
2017/3/18:00:31:32 Maria Elena LAPTOP-GELMANU4 Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:00:31:32 Maria Elena LAPTOP-GELMANU4 Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:00:31:33 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:00:31:37 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:00:32:54 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIFAA7.tmp
2017/3/18:00:33:04 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:00:32:56 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:00:32:56 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:00:32:56 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIFAA7.tmp
2017/3/18:00:32:56 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:00:32:58 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:00:32:58 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:00:32:58 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AIFAA7.tmp\Setup\AcSetup.dll
2017/3/18:00:32:58 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:00:32:59 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:00:33:10 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:00:33:10 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:00:33:10 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:00:33:16 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:00:33:17 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:33:18 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:00:33:19 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:00:33:19 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:00:33:19 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:00:33:20 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:00:33:21 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:00:33:21 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:00:33:31 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:00:33:32 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:00:43:59 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:00:43:59 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/18:00:43:59 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/18:00:44:00 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:00:44:37 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:01:36 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:01:36 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:01:36 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI2F35.tmp
2017/3/18:01:01:36 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:01:36 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:01:01:37 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:01:01:37 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AI2F35.tmp\Setup\AcSetup.dll
2017/3/18:01:01:37 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:01:01:37 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:01:01:31 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI2F35.tmp
2017/3/18:01:01:46 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:01:46 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:01:46 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:01:56 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:01:01:56 Maria Elena LAPTOP-GELMANU4 Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=it-it SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={B167238D-E6FA-432D-968A-BBB82C9BB71E} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:01:01:58 Maria Elena LAPTOP-GELMANU4 Install Network License Manager Succeeded
2017/3/18:01:01:59 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:02:00 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:01:02:01 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:01:02:02 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:02:02 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:01:02:03 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:01:02:03 Maria Elena LAPTOP-GELMANU4 Download Skipped CADM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CADM_x64_...
2017/3/18:01:02:03 Maria Elena LAPTOP-GELMANU4 Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=it-it SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,Microsoft Visual C++ 2012 Redistributable (x86) Update 4,Microsoft Visual C++ 2012 Redistributable (x64) Update 4,Microsoft Visual C++ 2015 Redistributable (x86),Microsoft Visual C++ 2015 Redistributable (x64),;;;;" PACKAGEUPI={B167238D-E6FA-432D-968A-BBB82C9BB71E} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:01:02:06 Maria Elena LAPTOP-GELMANU4 Install Autodesk CAD Manager Tools Succeeded
2017/3/18:01:02:07 Maria Elena LAPTOP-GELMANU4 Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:01:02:07 Maria Elena LAPTOP-GELMANU4 Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:01:02:08 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:01:02:13 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:01:06:47 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AICA.tmp
2017/3/18:01:06:55 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:06:50 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:06:50 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:06:50 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AICA.tmp
2017/3/18:01:06:50 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:06:51 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:01:06:51 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:01:06:51 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AICA.tmp\Setup\AcSetup.dll
2017/3/18:01:06:51 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:01:06:52 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:09:29 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:09:29 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:01:09:29 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:09:46 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:01:09:48 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:09:48 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:09:48 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:01:09:48 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:01:09:49 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:01:09:49 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:09:49 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:01:09:51 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:01:09:51 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:09:51 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:01:09:52 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:01:09:52 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:01:09:52 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:01:10:17 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:01:10:18 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:22:43 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:22:43 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/18:01:22:43 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/18:01:22:44 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:01:24:35 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:01:31:31 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIA368.tmp
2017/3/18:01:31:39 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:31:34 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:31:34 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:31:34 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIA368.tmp
2017/3/18:01:31:34 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:31:35 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:01:31:35 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:01:31:35 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AIA368.tmp\Setup\AcSetup.dll
2017/3/18:01:31:35 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:01:31:36 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:31:39 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:31:39 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:33:27 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:01:33:28 Maria Elena LAPTOP-GELMANU4 Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=it-it SETUP_PACKAGENAME="Autodesk® AutoCAD® 2017" SETUP_PACKAGECODE={12D88A40-9001-4FBB-8B99-92A0C62B981C} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={B167238D-E6FA-432D-968A-BBB82C9BB71E} ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk AutoCAD 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/3/18:01:33:29 Maria Elena LAPTOP-GELMANU4 Install Network License Manager Succeeded
2017/3/18:01:33:30 Maria Elena LAPTOP-GELMANU4 Download Play SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:01:33:30 Maria Elena LAPTOP-GELMANU4 Download Complete SUCCESSMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SUCCESSMA...
2017/3/18:01:33:30 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:01:33:46 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:01:35:28 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI3F1D.tmp
2017/3/18:01:35:36 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:35:30 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:35:30 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:35:30 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI3F1D.tmp
2017/3/18:01:35:30 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:35:31 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:01:35:31 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:01:35:31 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AI3F1D.tmp\Setup\AcSetup.dll
2017/3/18:01:35:31 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:01:35:32 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:36:33 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:36:33 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:01:36:33 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:37:31 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:01:37:32 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:37:32 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:37:32 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:01:37:32 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:01:37:33 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:01:37:33 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:37:33 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:01:37:33 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:01:37:34 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:37:34 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:01:37:34 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:01:37:34 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:01:37:34 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:01:37:43 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:01:37:44 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:45:29 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:45:29 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/18:01:45:29 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2017/3/18:01:45:30 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:01:46:22 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:01:47:08 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIF27E.tmp
2017/3/18:01:47:17 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:01:47:10 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:01:47:10 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:01:47:10 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AIF27E.tmp
2017/3/18:01:47:10 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:01:47:11 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:01:47:11 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:01:47:12 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AIF27E.tmp\Setup\AcSetup.dll
2017/3/18:01:47:12 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:01:47:12 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:47:22 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:47:22 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:01:47:22 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:47:28 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:01:47:28 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:47:28 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:47:40 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:47:40 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:47:46 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:47:46 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:01:47:55 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:01:47:55 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:01:47:55 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:01:49:41 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:49:42 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:01:49:43 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:01:49:43 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:01:49:43 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:01:49:44 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:01:49:44 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:01:49:44 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:01:49:53 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:01:49:54 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:51:50 Maria Elena LAPTOP-GELMANU4 Download User Pause CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:51:50 Maria Elena LAPTOP-GELMANU4 Download Paused CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:51:54 Maria Elena LAPTOP-GELMANU4 Download User Cancel CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:51:55 Maria Elena LAPTOP-GELMANU4 Download Play CANCELMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CANCELMAR...
2017/3/18:01:51:55 Maria Elena LAPTOP-GELMANU4 Download Complete CANCELMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CANCELMAR...
2017/3/18:01:51:56 Maria Elena LAPTOP-GELMANU4 PageOpen InstallCompleteDialog
2017/3/18:01:51:59 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:01:52:00 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:02:33:26 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:02:33:26 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:02:33:26 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Autodesk\AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT
2017/3/18:02:33:26 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:02:33:26 Maria Elena LAPTOP-GELMANU4 CommandLine /PK 001I1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/AutoCAD_2017_Italian_Win_32_64bit_wi_it-IT_Setup..."
2017/3/18:02:33:27 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:02:33:27 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI4DC1.tmp
2017/3/18:02:34:27 Maria Elena LAPTOP-GELMANU4 === Setup ended ===
2017/3/18:02:33:32 Maria Elena LAPTOP-GELMANU4 === Setup started on LAPTOP-GELMANU4 by Maria Elena ===
2017/3/18:02:33:32 Maria Elena LAPTOP-GELMANU4 Path_Length: 162
2017/3/18:02:33:32 Maria Elena LAPTOP-GELMANU4 Current Directory C:\Users\MARIAE~1\AppData\Local\Temp\_AI4DC1.tmp
2017/3/18:02:33:32 Maria Elena LAPTOP-GELMANU4 Launch
2017/3/18:02:34:26 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUPMARK...
2017/3/18:02:34:26 Maria Elena LAPTOP-GELMANU4 Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/SETUP_x64...
2017/3/18:02:34:26 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\MARIAE~1\AppData\Local\Temp\_AI4DC1.tmp\Setup\AcSetup.dll
2017/3/18:02:34:26 Maria Elena LAPTOP-GELMANU4 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/3/18:02:34:26 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:02:34:36 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:02:34:36 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:02:34:43 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:02:34:43 Maria Elena LAPTOP-GELMANU4 PageOpen LaunchDialog
2017/3/18:02:34:53 Maria Elena LAPTOP-GELMANU4 PageOpen LicenseDialog
2017/3/18:02:34:53 Maria Elena LAPTOP-GELMANU4 PageOpen ProductInfoDialog
2017/3/18:02:34:53 Maria Elena LAPTOP-GELMANU4 PageOpen ProductSelectionDialog2
2017/3/18:02:35:12 Maria Elena LAPTOP-GELMANU4 PageOpen FullProgressDialog
2017/3/18:02:35:14 Maria Elena LAPTOP-GELMANU4 Download Play STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:02:35:14 Maria Elena LAPTOP-GELMANU4 Download Complete STARTMARKER http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/STARTMARK...
2017/3/18:02:35:14 Maria Elena LAPTOP-GELMANU4 Download Skipped UCRT http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/UCRT_x86....
2017/3/18:02:35:14 Maria Elena LAPTOP-GELMANU4 Installing Universal C Runtime (KB3118401): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2017/3/18:02:35:15 Maria Elena LAPTOP-GELMANU4 Install Universal C Runtime (KB3118401) Succeeded
2017/3/18:02:35:15 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X86 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:02:35:15 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/3/18:02:35:16 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1638
2017/3/18:02:35:16 Maria Elena LAPTOP-GELMANU4 Download Skipped VCREDIST2015X64 http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/VCREDIST2...
2017/3/18:02:35:16 Maria Elena LAPTOP-GELMANU4 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\MARIAE~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/3/18:02:35:16 Maria Elena LAPTOP-GELMANU4 Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1638
2017/3/18:02:35:17 Maria Elena LAPTOP-GELMANU4 Download Skipped DIRECTX http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/DIRECTX.t...
2017/3/18:02:35:17 Maria Elena LAPTOP-GELMANU4 Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2017\3rdParty\DirectX\DXSETUP.exe" /silent
2017/3/18:02:35:36 Maria Elena LAPTOP-GELMANU4 Install DirectX Runtime Succeeded
2017/3/18:02:35:37 Maria Elena LAPTOP-GELMANU4 Download Play CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:02:45:13 Maria Elena LAPTOP-GELMANU4 Download Aborted CM http://edutrial.autodesk.com/NET17SWDLD/2017/ACD/WI/{73DC9D93-65F3-4C37-A9FD-5793A7F8490C}/CM.tar.lz...
2017/3/18:02:45:13 Maria Elena LAPTOP-GELMANU4 Install Autodesk Material Library 2017 Failed Download Failed, Installation aborted, Result=1603
2017/3/18:02:45:13 Maria Elena LAPTOP-GELMANU4 Rollback DirectX Runtime Failed Failure is ignored, Result=1619
thank you very much
@Anonymous
Welcome to the community...
Your installation is simply failing due to the method (web installer) you're using. This method is unreliable and shouldn't be used.
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I'm trying to find ORCA to solve it: DirectX Runtime Failed Failure is ignored, Result=1619
Where can I find it?
@Anonymous
Most likely the 1619 error that you have is not the problem. Share your installation log file so we can direct you to the correct solution. However sometimes log file contain personal info such as your serial #. Please make sure to remove that info before sharing.
Mark Lancaster
I hope that I'm right and the attached is the installation log file .
Hope you can help me. I just need to Install Autocad 2018.
This is a public forum, please refrain from posting serial numbers or personal information
Edited by
Discussion_Admin
@Anonymous
I guess you didn't read my warning about posting a log file with your serial #..
Mark Lancaster
Hi Mark.Lancarster,
Solved! I installed Acad 2018, I also activated it.
Thanks!!!!!!!!!!!
There is no file with name acad.msi
I also attach screenshot and log file
@Anonymous
Welcome to the Autodesk User's Community'
Sorry that you are faced with this problem.. A 1603 failure on a core Autodesk product.. Not good.
See @TravisNave and my information in this posting. Some users have had success in reinstalling Windows but that's not really a viable solution. If something does work for you please let us know because to this date no one has indicated any success in getting over the 1603 error on a core product installation.
Mark Lancaster
Hello @Anonymous,
Were you able to uninstall it? Let us know if you were able to resolve this. Thank you.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Since this was 5 years ago and the people were involved are no longer with the company, i can only assume the issue has been resolved.
