so, everything is fine, until i reinstall the win10, i already did this
still not working, i had repair it , reinstall it, still cant halp.
anyone can help?
Solved by Darin.Green. Go to Solution.
Is it an older version of autocad that isn't compatible with windows 10? The article you linked is from 2014 and 2014 and back versions of autocad will not work with windows 10. If they do work they will most likely break at some point with an update.
Nick DiPietro
Cad Manager/Monkey
@Anonymous,
Reinstalling windows 10 is a big deal, which in most cases would break every installed application on the machine (non-windows related). I recommend performing the following task:
That should get you back in business.
If this information was helpful, please consider using the Accept Solution
Darin Green
Director of Customer Support
Synergis Engineering Design Solutions
Facebook | Twitter | LinkedIn
