Installation & Licensing
Message 1 of 9
ToddRogers-WPM
242 Views, 8 Replies
Deployments
So, the new deployment creation is still junk. The only way to configure file paths is to export out a profile.arg file. However, doing so, and attaching it to the deployment DOES NOT WORK. It totally ignores the file and just creates the deployment without it. Anyone else experiencing this?????
Todd Rogers
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: ToddRogers-WPM
read this: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Customisations-con...
DarrenP
Message 3 of 9
Thanks D-man. That's a bunch of crap man. Get rid of the uninstall tool and move to a crappy deployment system. Wow. I love my job...lol.
Todd Rogers
Message 4 of 9
Tried every single solution mentioned in the article and NONE of them worked. Wow.
Todd Rogers
Message 5 of 9
DarrenP
i'm finding other threads with this not working no solution has been offered
you may want to create a case
DarrenP
Message 6 of 9
Cases come to me...lol. I can escalate though.
Todd Rogers
Message 7 of 9
GaryOrrMBI
Just in case anyone from Autodesk is listening, which I doubt they are, the custom Revit.ini file (for a Revit 2024 deployment) is experiencing a similar issue:
ie: the ini file that was uploaded to become part of the deployment was corrupted by the deployment tool. OK, not actually corrupted (as in the file can still be opened in notepad and the like), just poorly copied into the deployment. The file that the deployment created did not have any line breaks in it and is therefore unusable.
[Revit.ini][Colors][Directories]ProjectPath=%USERPROFILE%\Documents\Autodesk\Revit 2024ImportLineweightsNameDWG=C:\Program Files\Autodesk\Revit 2024\Data\importlineweights-dwg-default.txtMaterialLibraryFiles=..\Data\RenderingIESFileLocation=C:\ProgramData\Autodesk\RVT 2024\IES\LookupTableLocation=C:\ProgramData\Autodesk\RVT 2024\Lookup Tables\
instead of:
[Revit.ini]
[Colors]
[Directories]
Yes, I know how to fix it (replace the file in the deployment package with a valid one) but...
The point is, the deployment tool is broken... again...
Gary J. Orr
GaryOrrMBI (MBI Companies 2014-Current)
aka (past user names):
Gary_J_Orr (GOMO Stuff 2008-2014);
OrrG (Forum Studio 2005-2008);
Gary J. Orr (LHB Inc 2002-2005);
Orr, Gary J. (Gossen Livingston 1997-2002)
Message 8 of 9
Thanks for this, as we do have to update the Revit .ini file.
Todd Rogers
Message 9 of 9
GaryOrrMBI
Well, while you're at it...
I tried packaging Revit and Navisworks into a single deployment...
Didn't work...
The deployment installed Navisworks, then forced a restart, then did not take up the remaining Revit installation after the restart, I had to run it again manually to get my messed up Revit installed.
-G
Gary J. Orr
Administrator Productivity
