I have been trying to get my Fusion 360 to work for one month now. This process has been very aggravating.
I keep getting unable to connect to internet issue:
1. I've uninstalled and reinstalled
2. I've installed Fiddler 4 and followed the directions
3. I created a support ticket CaseNo:16621178.
a. support told me the time stamp was too old on my appdata/autodesk attachment file, even though the file was created immediately after I got the error:
"Unable to connect to the internet.
Please check your internet network connection. You need to sign into your Autodesk Account to use Fusion 360."
b. support never responded after I sent a new appdata/autodesk attachment file on June 9th.
c. now my appdata/autodesk folder has disappeared and can't be found when searched for.
I really need help with this and it's becoming quite aggravating. I have been missing out on 1 months worth of opportunities because this software has been so problematic to install from the IDverification through installation.
Please help me get this software to function.
Hello @Anonymous,
Thank you for all the information provided.
Your log indicates that you are receiving a "WARNING :: Failed to get network connection information [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond"
A WinError 10060 is a Microsoft error where "timeout errors may occur on slow, congested, or high latency Internet links".
I have listed some steps for you to conduct below to resolve the issue:
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
