Fresh install of Windows 10 64-bit, trying to build a lab image. No antivirus installed yet, so that is not the issue. Using local administrator account, tried both with and without "Run as administrator". I have tried it also on several other lab machines of wildly varying hardware, and I get this error everywhere. Downloaded the installer yesterday, tried downloading a fresh copy just now and both behave the same.
My co-worker figured it out (no response from Autodesk to my post or my related help ticket):
Installer won't run on an older version of Windows 10 LTSB. Updated the OS to Windows 10 LTSC 2019 and installer now works. Autodesk should specify what versions of Windows the software will work on. If it's going to be that picky, the installer should at least give you a reason for failing!
