Installation & Licensing
can't reach installed components
4 REPLIES 4
robertawalker
177 Views, 4 Replies
when i open autocad the following appears
this is generally not a problem but yesterday i was trying to edit a block and the same thing came up and i had to stop autocad from the task manager and reload a saved copy of the drawing. Any suggestions as to what is causing this.
Tags (1)
4 REPLIES 4
paullimapa
in reply to: robertawalker
If  you start AutoCAD in safemode and the error doesn’t come up then it could be one of the addons installed. You may want to uninstall the offending one
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-launch-an-A...
Paul Li
IT Specialist
@The Office
I have tried but cannot start AutoCAD in safemode.
robertawalker
in reply to: paullimapa
paullimapa
Time to try a reset and if that doesn’t work then a repair or reinstall
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC....
Paul Li
IT Specialist
@The Office
Administrator Productivity
