Installation & Licensing
Can't install on Mac. [Errno 13] Permission denied
8 REPLIES 8
Message 1 of 9
1381 Views, 8 Replies
I had this same issue previously when trying to install Fusion 360. The only way I could get the software to run was by downloading direct from the Mac App store. Now Autodesk is pulling the App store software I need to get this Autodesk downloaded software running. I'm hitting the same walls as previous.
Screenshot attached of error message. Log file also attached.
I am running a MacBook Pro 15-inch, Mid 2012, 2.6GHz with 16GB Ram.
On macOS Mojave. Version 10.14.4
I have seen there have been several other cases of the same issue (or similar) on the Autodesk support forums. There does not seem to be a solution or feedback from Autodesk on this that I can find.
Help would be appreciated. As it stands I am unable to run the software.
Thanks, Mike.
8 REPLIES 8
Message 2 of 9
Ummm, bump. Have not heard anything yet, or had any help from Fusion 360 Support on this?
Problem is still very much persisting.
Message 3 of 9
Was there ever a solution given for this issue? I'm in the same boat, and have not received a reply.
Thanks in advance,
Nick
Message 4 of 9
Mark.Lancaster
@Anonymous
Can you provide the related installation log file
Or review this:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fusion-360-Installation-Errno-13-Permission-Denied.html?_ga=2.11463923.69887588.1582048161-1825845532.1563196738
Mark Lancaster
Message 5 of 9
I have the same problem.
Have run AutoDesk cleaners, manually cleaned library, turned off Firewalls and security. Tried everything. Still get same message. very Frustrating.
Message 6 of 9
leowarren34
Hi @Anonymous,
Can you upload your installation log file?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-manually-collect-the-log-files-for-Autodesk-Fusion-360.html
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 7 of 9
in reply to: leowarren34
[image: Screen Shot 2020-06-11 at 12.09.27 pm.png]
Hi
Here is the log file. I' ve run out of ideas as to how to get it to
install.
Very frustrating. Any help would be greatly appreciated.
Cheers
Cass
Message 8 of 9
leowarren34
@Anonymous You haven't attached anything
Did you reply via email - you can't attach files to forum posts via email.
Leo Warren
Message 9 of 9
mdavis22569
@Anonymous
I'd start a new post ... you're on one from 2019.  I'd do it clean and based on your OS / Software having an issue.  This will help those who might have this issue as well with that OS and Software
Best
Mike
Mike Davis
Administrator Productivity
