If you care for REAL life prices
Q6600= e8400 in money- but 2x faster in max for rendering, because it has 2x more cores.
So, just so I know that I’m on the same page as you, if I have a single core processor running at 2.5GHz and a Quad Core Processor running at the same speed and I set them both up to render the same image/frame the quad core would get done in a fourth of the time that the single processor finishes? |
In theory- yes. In practice, chance are that the single core is based on the old architecture and it will be more than 10x slower than the quad.
For example, my old Pentium 4 Celeron 320d Prescott 2.4ghz OC to 3.6ghz is 90x slower than my new core 2 quad 6600 2.4ghz OC to 3.0 ghz.
While in theory it should be under 4x slower, in actual- its 90x(no typo) slower. Just to reiterate that means that a frame that takes 1:30min on my celeoron takes 1(one) sec on the quad. Nice difference. This extreme difference is measurable only in Mental Ray rendering; in other areas difference is nowhere near as big, while still present in at least 1:4 speed- where the single core is at least 4x faster.
In theory, if by some miracle you should find the single core of the “core2” cpu working alone, it should be 4x slower than core2 quad.
I’m just a little confused about if I have a quad core would it speed up render time. I’m sure that going from my crap anthron AMD 2.08GHz to any quad core would see a significant difference, but is it worth the money? |
Well, if you browse the web and listen to music- hardly. If you do ANY sort of work in Max, than yes. New quad should be over 100x faster for rendering than your current Athlon.
but all I mean by it is that is...would it speed up render times to a noticeable rate? |
I think you will be able to notice
at least 100x faster renderings.
