Installation & Licensing
Bad image after Install
7 REPLIES 7
Message 1 of 8
9802 Views, 7 Replies
So I installed the student version of Maya 2016 for my Laptop (Windows 10) via the install now option. No apparent issues, but for some reason when I try and open it I get the following error:
How do I solve this?
7 REPLIES 7
Message 2 of 8
Otto
Otto
Hello tshepp121 and welcome to the Autodesk community!
It looks like you are experiencing issues with your product on Windows 10 or want to know which Autodesk products are supported on Windows 10. Community members with similar questions found the following article(s) useful:
Windows 10 support for Autodesk products
Other threads about Windows 10 support
Change your mind about Windows 10? Here's how you can roll back
Please consider bookmarking this page and checking back often; we'll update with new information as our testing continues.
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
jeffrey.sin
jeffrey.sin
Hi @Anonymous,
Welcome to the Community.
It could be related to the Microsoft Visual C++ Redistributable package, check out the solution from this article: Error: "The program can't start because MSVCR110.dll is missing from your computer." when using Autodesk products
Alternatively, try re-installing the software by re-downloading the installer from the Virtual Agent instead. Let us know how it goes.
Thank you,
Jeffrey Sin
Autodesk Customer Support
Hi @Anonymous,
Thank you,
Jeffrey Sin
Message 4 of 8
in reply to: jeffrey.sin
Thanks a lot, it seems the C++ files were causing the issue.
Message 5 of 8
You can go to the 3Ds max file location, (Windows (C) -- Programme Files-- autodesk-- 3ds max design) see either which dll files size is 0 KB, please list down the name of that file and ask your friends who is using the same version of 3ds max software, ask her/him to check his files which you lost and email to you those files. After you received , please save it into your your 3Ds max design file location (Windows (C) -- Programme Files-- autodesk-- 3ds max design) and replace the original files. Last, you try to open your 3dsmax file again, it should be sholved. Hope this solution may help you to solve that problem.
Message 6 of 8
Hello.
I have been using Fusion 360 for almost a year now on a hobby licence its due to run out in November.
I have just tried to open the software and a bad image notification appeared as per the previous thread.
Do i have to uninstall and reinstall from the Virtual agent to solve the problem.
What will happen to all my project folders? will they be installed when i log back onto the new software?
Regards
Dave.
Hello.
Regards
Dave.
Message 7 of 8
Mark.Lancaster
Mark.Lancaster
@Anonymous
I would recommend that you perform a Fusion 360 clean uninstall and reinstall.  Fusion 360 is a cloud based software so its not on the Autodesk Virtual Agent.  Just download the free trial again and sign in to authorize your subscription.  No projects/files will be lost since they are stored in the cloud.
Mark Lancaster
@Anonymous
Mark Lancaster
Message 8 of 8
in reply to: Mark.Lancaster
Hello Mark.
Thanks very much for the information. The procedure worked very well I am now up and running.
Thanks again.
Dave.
Hello Mark.
Thanks again.
Dave.
Administrator Productivity
