Installation & Licensing
Autodesk Self Extract stuck for Maya 2016
6 REPLIES 6
1504 Views, 6 Replies
I am currently trying to install Maya 2016 Extension 2 and Mental Ray onto my computer, but as soon as I get to the "Self Extract step" I start to have problems. After confirming the destination folder (C:\Autodesk\) for the extraction, the bar does not load and if I try to cancel the tab it stays frozen on my screen. If anyone has the solution I would be very grateful!
6 REPLIES 6
matthew.d
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Have you tried installing from the virtual agent yet?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Hi @Anonymous,
Matt DiMichele
in reply to: matthew.d
Hi Matt!
I haven't tried that, could you tell me how the virtual agent could help solve my problem? Just in case you need to know, the current version of Maya I am using is Maya 2016 with the Service Pack 6 update installed.
Hi Matt!
matthew.d
matthew.d
Hi @Anonymous,
I think I missed the extension 2 part in the first entry. My apologies. Are you downloading the extension from the desktop app or from you Autodesk Account? I'd recommend trying from you Autodesk Account with your antivirus disabled. Do you have any pop-up blockers enabled. There is also a service pack (1) for extension 2 by the way, which can be found here.
Matt DiMichele
Hi @Anonymous,
Matt DiMichele
Ah, no worries. After your suggestion, I tried using my Autodesk Account to download both Extension 2 and Mental Ray Plugin, with my anti-virus disabled too, but it still didn't work. There were no pop-up blockers either. The actual download was fine I think, it's once I opened up the download and tried starting the self extract that I had a problem. The bar is still stuck at 0% too, the same as before.
matthew.d
matthew.d
Hi @Anonymous,
Apologies that you are still having trouble with this. Are you running the file extraction, as the admin? Have you also tried the suggestions on this thread?
Matt DiMichele
Hi @Anonymous,
Matt DiMichele
It finally worked after running it as the admin in the properties, like you said! Thank you so much!
Administrator Productivity
