autocad2023 #serial number
rahmantanisa101
Observer
Observer
rahmantanisa101
Observer
Observer
I cannot find my serial key. hence cannot use AutoCAD. it's showing the improper install
Accepted solutions (3)
Autodesk doesn't provide serial numbers
leowarren34
Hi @rahmantanisa101,
You can find your license details at https://manage.autodesk.com/,
In all likelihood, you won't have a serial number due to them being phased out in most cases, being replaced by signing in using your AutodeskID.
Hope that helps.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
pendean
Community Legend
Community Legend
You want to LOGIN and not seek out a serial number when that pop-up appears: do that instead.
OR... Start and log into the Autodesk Desktop App with your Autodesk Account credentials then start AutoCAD 2023
mdavis22569
@rahmantanisa101
Were you able to get this resolved?
As Pendean mentioned you should just have to login now for the activation .. as almost all are named user activation.
Also with what Leo mentioned, you can look in your account manager to see what type of license you have and if it says "SIGN IN" next to your activation
Like this
Mike Davis
mdavis22569
@rahmantanisa101  Checking the status of this again ...
Mike Davis
mdavis22569
@rahmantanisa101  Were you able to get this resolved ...
Mike Davis
