I cannot find my serial key. hence cannot use AutoCAD. it's showing the improper install
Solved by mdavis22569. Go to Solution.
Solved by pendean. Go to Solution.
Solved by leowarren34. Go to Solution.
Hi @rahmantanisa101,
You can find your license details at https://manage.autodesk.com/,
In all likelihood, you won't have a serial number due to them being phased out in most cases, being replaced by signing in using your AutodeskID.
Hope that helps.
Were you able to get this resolved?
As Pendean mentioned you should just have to login now for the activation .. as almost all are named user activation.
Also with what Leo mentioned, you can look in your account manager to see what type of license you have and if it says "SIGN IN" next to your activation
Like this
@rahmantanisa101 Checking the status of this again ...
@rahmantanisa101 Were you able to get this resolved ...
